07-14-2020, 15:44 | #346 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2210593 Status: Offline Thanks Meter: 0 | Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000E49112BF4082 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): BDB2E491 Firmware version: 0143.02 Box/Dongle misconfiguration Diagnostic code: 66 "UK Edition" status: Off Last launched Application: 0030 v.0143 => Activations: - 00: Infinity-Box/Dongle v0143 => Options: - Infinity-Box/Dongle plz help cm2mt2 warning: dongle misconfiguration error solution |
07-14-2020, 16:03 | #347 (permalink) | |
Attach fault.bin file from Infinity software folder | |
07-25-2020, 07:50 | #352 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1093509 Status: Offline Thanks Meter: 5 | === DongleManager [Infinity] v1.80 [7/24/2020 23:48:56] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000012A321344082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 104C12A3 Firmware version: 0144.02 === Process started: 7/24/2020 23:48:57 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
07-25-2020, 10:23 | #354 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Problem is not serious ! Your PC has some kind of incompatibility or maybe you are using some kind of danger software. Infinity Team supporters will help you to fix your PC ! STEP 1: go to folder C:\InfinityBox\CM2MT2\ or C:\InfinityBox\CM2SP2\ STEP 2: find file fault.bin STEP 3: upload file to https://mega.nz/ or send to support via e-mail - https://www.infinity-box.com/contact/ | |
07-25-2020, 10:52 | #357 (permalink) | |
Member: 1093509 Status: Offline Thanks Meter: 5 | Quote:
and i changed my windows also | |
07-25-2020, 14:49 | #358 (permalink) | |
now you can update dongle with DongleManager, probably it will be fixed | |
07-26-2020, 05:32 | #359 (permalink) |
Member: 1093509 Status: Offline Thanks Meter: 5 | Sir i mean ,i search the File in Cm2 MT2 Install Directory ,But there is No Fault file . now what should i do. plz help me sir out of this problem. i purchased the 2 month ago. |
07-26-2020, 06:26 | #360 (permalink) | |
https://mega.nz/file/gF53EBiR#drgf4g...nMS78OBPoM0mz8 ok Sir this is my file | |
The Following User Says Thank You to fawadahmadbj For This Useful Post: |
