08-14-2008, 03:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: In front of my pc
Member: 586318 Status: Offline Thanks Meter: 112 | Dongle not found after upgrading with pinfinder thanks. |
08-14-2008, 07:10 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, There is no any relation with PinFinder upgrade and dongle functionality. You need to reboot PC, double check cables from PC to box, double check that smart-cart is inserted well in box card-holder. |
08-14-2008, 16:16 | #3 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | @ InfinitySupport. I did exactly as you say but there is no solution yet. The Infinity box indeed get power from usb port 'cause red led is always on, it is not blinking is permanent on. Besides, when I check in device manager; in port settings there is no one that infinity take control of it. Here I show you my error message. Something else, I think it is not smart-card 'cause if were smart-card; software will give a smart-card error message but in this case is not shown. Just one more datum, I tried in other PC but the same problem is faced. Thanks for your answer but I just tried everything but do not worked. |
08-14-2008, 17:16 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Send DongleManager.log file to [email protected] Include in your mail detailed explanation of situation and all steps that you have tried to do. |
08-15-2008, 00:25 | #6 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | I did exactly as you said in the e-mail you sent me, but nothing yet. Do you have any other idea that can help to solve this issue. What I really make me doubt is that before using pind finder everything was ok, but after I am how I am, stuck with a dead box. |
08-15-2008, 15:53 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | For sure your problem is NOT related with PinFinder. If you have any other box with smart-card you can try to insert Infinity-Box smart-card in other box and try to run Infinity-Box software. What is the results ? |
08-15-2008, 18:32 | #9 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | After swapping smart-cards here are the results: 1.- I put infinity smart-card into rocker dongle and then in ust pro II box and try to run infinity software and the computer restart by itself. 2.- With infinity smart-card into these two boxes (UST PRO II and RockerDongle) try to run their respectives softwares and the same, computer restart by itself. 3.- Installing RockerDongle and UST PRO II smart-cards in infinity and running infinity software; software says "DONGLE NOT FOUND". So, as far as I notice the pinfinder screw my infinity box! |
08-15-2008, 19:48 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Let me repeat: I don\'t think that PinFinder can make any damage for box. As per your tests: Accordint to result of test #1 and #2 I think that you need to re-install smart-card drivers. According to test #3 it looks like box is damaged, you must double check card holder contacts and check box PCB soldering. Also you can try to use box at other PC and see results. |
08-15-2008, 23:36 | #11 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | I tried with other pc but still the same problem. What I said and notice so strange is that even computers do not detect the dongle as a new hardware |
08-17-2008, 04:04 | #12 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | Last tests: I unistall all boxes (Infinity, Ust Pro II, Smart Clip, Advance Box BB5, Rocker Dongle, Ufs3 Tornado with hwk, SE toolbox3) and unistall some aditional software like F&B 3.0.5, RSD lite, Mobile phone tools, etc. then I install Infinity drivers and main software and with rocker dongle box with infinity smart-card install this box just like if the same were the infinity one and eureka the infinity software works fine. After doing this I release infinity-smart card from rocker dongle and inster rocker dongle smart-card and install rocker dongle driver and main software and install this box as roncker dongle and run main software and worked fine. So, in conclusion the infinity box is damaged, now my answer is how and why?, well just another question: should I use pinfinder module with rocker dongle box, should I be afraid to get my rocker dongle box damaged too, after using pinfinder? My infinity is under warranty, what are the steps to get a new one without cables and smart-card? should I get contact with reseller or with infinity support team? |
08-17-2008, 11:16 | #13 (permalink) |
Product Supporter Join Date: Mar 2005 Age: 44
Member: 128745 Status: Offline Thanks Meter: 16,936 | for warranty you must get in contact with your infinity box reseller, if he does not help you mail me [email protected] |
08-17-2008, 12:55 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | As about PinFinder usage: you can use it with any Unibox (Infinity-Box or another unibox that has the same pinout). Infinity-Box pinout is shown in PinFinder manual at end page and in Infinity-Box Shell. I dont think that PinFinder can make any damage for unibox, but to be completely sure check PinFinder input connector, pin 1 and pin 8 should be not shorted (it\'s power pins). If these pins is not shorted you can connect and use PinFinder with other unibox. |
08-30-2008, 03:44 | #15 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | @ InfinitySupport, Dear mate I would like to get the infinity box from you 'cause I am not 100% satisfy with the answers I got from my reseller. So, are you able to sell me one new infinity box without smart-card and without cables. How much will it cost me? |
dongle not detected after upgrade | gabriel148 | Scout | 1 | 10-09-2008 08:38 |
help interface not found after upgrade... | kevin182029 | Smart-Clip | 1 | 01-21-2008 10:12 |
Device Not Found, but working with Upgrade Tool | Seedy | SagMaster Team OLD Products | 9 | 03-09-2006 19:54 |
After Update Dongle Not Found | bozan | SagMaster Team OLD Products | 6 | 02-12-2005 12:39 |
