05-12-2019, 23:26 | #1 (permalink) |
Freak Poster Join Date: Nov 2014 Location: İstanbul
Member: 2291790 Status: Offline Thanks Meter: 45 | Doro 2404 DFC-0130 MTK6261 IMEI Repair Problem Doro 2404 DFC-0130 MTK6261 IMEI Repair Problem Log Code: Card found : S/N : 4B1E57BB , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : B2320F20E457168F5C3A1D40A39C5F78 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 That phone not have NVM area! Nothing to do! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : B2320F20E457168F5C3A1D40A39C5F78 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6261 SW : 2404_DF244_N_S01A_V11_M180628_MP HW : SAGETEL61A_11C_HW IMEI[1] : 358417082713474 IMEI[2] : 358417082713482 Update IMEI[1] to : Update Failed! Verify Failed! Update IMEI[2] to : Update Failed! Verify Failed! Done! Done! Elapsed: 00:00:40 Reconnect Power/Cable! Code: Card found : S/N : 4B1E57BB , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : B2320F20E457168F5C3A1D40A39C5F78 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 File_Info : DORO2404_DF244_GF2418_PCB01_gprs_MT6261_S00.2404_DF244_N_S01A_V11_M180628_MP.bin FileVersion : 2404_DF244_N_S01A_V11_M180628_MP Done! Elapsed: 00:00:09 Reconnect Power/Cable! Screen Shot |
