Doro Phone Easy 609 Hi .. Have this phone in hand, how can I help to unlock it ? here is log, but all unlock function in v 1.58 is disabled . Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 0438A60199985258D359FFBCC572137F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1900 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00FC , [GigaDevice] GD25LQ256 [0] : FLASH_DIE : 00C8 0060 0019 0000 [0] : FLASH_LEN : 0x02000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 File_Info : DOVE01A_S01A_PCB01_gprs_MT6260_S00.DOVE01A-S01A_DORO609_L20EN_201_150724.bin FileVersion : DOVE01A-S01A_DORO609_L20EN_201_150724 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 0438A60199985258D359FFBCC572137F BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1900 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00FC , [GigaDevice] GD25LQ256 [0] : FLASH_DIE : 00C8 0060 0019 0000 [0] : FLASH_LEN : 0x02000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Reading Flash Content now ... Read Flash now Read Ok , 33554432 bytes read Check and collect compile info File_Info : DOVE01A_S01A_PCB01_gprs_MT6260_S00.DOVE01A-S01A_DORO609_L20EN_201_150724.bin FileVersion : DOVE01A-S01A_DORO609_L20EN_201_150724 [ScatCFG] : MT6260 / DOVE01A-S01A_DORO609_L20EN_201_150724 / NOR , SF Firmware saved to : C:\InfinityBox\CM2MTK\Read_out\DOVE01A_S01A_PCB01_ gprs_MT6260_S00\ Done! Elapsed: 00:01:54 Reconnect Power/Cable! |
Infinity team, mybe I posted in wrong section ? |
