02-11-2008, 10:17 | #1 (permalink) |
Junior Member Join Date: Aug 2007
Member: 572898 Status: Offline Thanks Meter: 1 | N87 Sim B Imei Cannot Write Today I have try a new model China N87, that the sim B imei cannot change. Here please find the log that I used for mode 1~3: ************************************************* Mode 1: Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 19200 error: connection failed ! Operation failed ! Finished, time used: 84 sec Power off phone now ! ************************************************** ** Mode 2: COM12 [VCP0] selected Action: imei imei write method: mode-2 new imei: 352101010304012 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... CPU: MT6205 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 99 sec Remove/Install battery now ! ************************************************** ** Mode 3: COM12 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: imei imei write method: mode-3 new imei: 352101010304012 Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #02 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #03 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb detecting chip #01 in region #00... flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error flash: SST AMD/Fujitsu std [def 0040x010000 0400x001000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00700000 flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 00300000 Detected eeprom/ffs address is non-standard: 00300000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00300000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00500000 ffs chip: 00 eeprom/ffs area: 00000000:00300000-007FFFFF reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\N87 - backup_eeprom_20080211-171224.B0E flash: BF7353FFFF0052:18E59F00000000 warning: detected/calculated [00400000/00800000] chip size mismatch, chip detection error Identification Done Manipulation... imei is not detected ! ************************************************** **** Sir I will send you the back up file can you help me to take a look? Regards, P.P. |
Kisen F350 Dual Sim 2nd Imei cannot change | md3862 | Infinity-Box | 13 | 05-02-2009 23:46 |
07 Aug 2008: "ChineseMiracle" v2.54: dual sim/mono-CPU imei #1, imei #2 write etc. | InfinitySupport | Infinity-Box | 41 | 09-05-2008 09:08 |
07 Aug 2008: "ChineseMiracle" v2.54: dual sim/mono-CPU imei #1, imei #2 write etc | SHANU | Service Products News & Updates | 0 | 08-07-2008 19:27 |
HELP E818/E810 Cannot WRITE IMEI | kitloy | NSPRO | 2 | 07-05-2008 03:18 |
e900 cannot write imei | _aZzz | NSPRO | 5 | 01-03-2008 12:30 |
