DTS11 can not format ffs seccont CPU!! I have one DTS11 sccond CPU can not release the call after EDING. I flahsed with a reeaded full flash but now I ca not format FFS and write its IMEI. I tried Manytimes. Please very urgent help. Regards COM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... CPU: MT6205 Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 115 sec Remove/Install battery now ! |
hello! to get connection and boot second MCU you must hold power button very long. about 30seconds. first you will get no reaction and while this phone will power On. you must still keep power button pressed. After some time first phone part will start and then it will call to boot second part. did you follow this like i said or released button earlyer? Try to use Complete Format and IMEI writing method-3 |
Actually Client has gone! anyway I respond you. after soft says press power on, I pressed and did not released until it say me the error above each time.. regards |
hello! this is because you did not try method-3 next time try all IMEI changing methods method-3 must work always |
