Old 11-14-2017, 17:00   #1 (permalink)
Member: 1677653
Thanks Meter: 2,769
uk.off file
dear infinity team & fellow user,
please i need link to download uk.off file
thanks in advance....
The Following 4 Users Say Thank You to Yusuf Lawal For This Useful Post:
Old 11-14-2017, 17:10   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Little search can help u,,by the way here u can download it https://mega.nz/#!UHokEIRY!ZK0Mo7Usy...fcwL7YhJb4HjHY
The Following 6 Users Say Thank You to princesaddam For This Useful Post:
Old 11-14-2017, 17:21   #3 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,273
uk.off
What is problem....
Check your dongle UK edition setting....
Use dongle manager...run and set UK option to OFF...
Old 11-14-2017, 17:24   #4 (permalink)
Member: 1677653
Thanks Meter: 2,769
Originally Posted by gile@gile View Post
What is problem....
with uk.off file, u don't need any process....
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 04-06-2018, 22:44   #5 (permalink)
Member: 1977119
Thanks Meter: 17
download from this ink https://www.4shared.com/postDownload...uk_online.html
The Following User Says Thank You to batsiraidick For This Useful Post:
Old 04-06-2018, 23:08   #6 (permalink)
xx0o0xx1's Avatar
Member: 2033150
Thanks Meter: 624
u can create an empty file and rename it to UK.OFF
simply 1.2.3
The Following 2 Users Say Thank You to xx0o0xx1 For This Useful Post:
Old 12-01-2018, 10:06   #7 (permalink)
Member: 2664255
Thanks Meter: 8
now show this sms cm2 access violation at address o04ea874 in module cm2scr.exe
Old 05-24-2019, 14:08   #8 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
Working methoud.
simply 1.2.3
Replace UK.off File And Enable imei option Work
Thanks
The Following 2 Users Say Thank You to papoo For This Useful Post:
Old 12-30-2019, 12:38   #9 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
Same problem, what wrong?
Old 02-12-2020, 09:12   #10 (permalink)
papoo's Avatar
Member: 188374
Sonork: 1000.2
Thanks Meter: 203
Window Problem
First Disable antivirus Reinstall CM2 Module.
If Not Work
Download Window iso image From Microsoft Web
And make boot able USB
Reinstall Fresh window and install CM2 Module
access voilation address Problem Solved.
TESTED MANY TIME.
Page generated in 0.17969 seconds with 8 queries
