03-13-2008, 12:46 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Dubao 777 and Auto Pin Finder But it did nt work Any suggestions ??? |
03-13-2008, 12:55 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, explain what cable you have used and what you have tried to do more detailed. Also download latest PinFinder manual: http://www.infinity-box.biz/download..._PinFinder.pdf Please, see page 18: Automatic pinout detection: Troubleshooting |
03-14-2008, 11:27 | #3 (permalink) |
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Cable was L18A (Is this correct ???) And I was trying to repair "Restarting with Sim" I was fixing it ok with soldering on PCB, but now, not working with auto pin finder. Also "Find It" procedure fails |
03-14-2008, 12:17 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! can not tell you if cable is coorect for your phone. you must count pins and choose between 18a and 18b check which one is fit there. have you succesfuly used pinout finder before or this is your first phone? can you power On phone for power lines? This is common mistake when users use Btemp battery contact and connect there Red wire. phone is not powerable On, pinout also can not be found under this conditions. |
03-14-2008, 15:41 | #5 (permalink) |
Freak Poster Join Date: Jul 2007 Location: ************ Age: 36
Member: 567351 Status: Offline Thanks Meter: 40 | @dannyogolo this phone don't have rx tx at connector. its have under lcd. remove lcd and there is 2 point at right side not marked as rx tx but they are rx and tx .. be side of 18pin connector. upper one is tx down one is rx |
03-14-2008, 16:59 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | thank you mr. cbz_4383 for confirming my words. sometimes even phones with very big system connector doesent have tx/rx pins in it. then we must solder wires to PCB |
03-14-2008, 17:34 | #7 (permalink) | |
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | tHANKS MAN Quote:
It works fine, easier than the way i was using b4. But I know it has rx and tx on connector: we were soldering from inside b4 u finely "interupted" | |
03-14-2008, 22:11 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! some uniboxes have very small output voltage on pin1. Also 0,7 volts is dropping on transistor which swith power to phone. so at the end we get voltages below 3,7 volts which is not enough to power On phone if you have on pinfinder output voltage below 3,7v- please modify your unibox there must be diode removed and set shortcut. Where is located this diode you can find in pin finder user manual in troubleshooting section |
Auto-Pin-Finder by Mr. SSP for Infinity-Box users | Miftahudin | Infinity-Box | 110 | 04-26-2009 17:42 |
Auto pin finder power problem | cellbhai | Infinity-Box | 6 | 02-25-2008 13:08 |
Please Help me To Activating Infinity Auto Pin Finder | shinta | Infinity-Box | 2 | 02-13-2008 14:52 |
Infinity Box - Auto Pin Finder Adapter!!! | Hams | Main Sales Section | 0 | 02-09-2008 18:13 |
Dubao 777 and 758 issues | ndagi | Infinity-Box | 4 | 11-24-2007 07:18 |
