07-14-2008, 05:29 | #1 (permalink) |
Banned Join Date: Dec 2002 Location: SWITZERLAND Age: 55
Member: 18329 Status: Offline Thanks Meter: 144 | e101 permanent blocked solve by infinity COM5 [VCP0] selected Device: Alcatel-E101 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... finalizing... Boot done Check connection... Check connection done Set baud... 115200 Set baud done Check hardware... flash: 012A7E2A242A00:54000000000000 flash: AMD/Fujitsu std [T 003Fx010000 0004x004000] 4Mb Check hardware done Read data... reading Alcatel-E101_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\backup_Alcatel-E101_eeprom_calibration-1_20080714-121551.80E.bin Read data done Check data... Check data done Writing... .. flash: 012A7E2A242A00:54000000000000 Write: simlock Writing done Finished, time used: 73 sec Remove/Install battery now ! |
The Following User Says Thank You to ricson For This Useful Post: |
07-14-2008, 13:07 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @ricson Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
11-08-2008, 14:49 | #7 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Vancouver
Member: 190184 Status: Offline Thanks Meter: 31 | I try to unlock this type of alcatel but it does not connect to box i can you please show picture of pinouts for e101 but also pinout how thay connect to infinity box and which rj45 and f-bus or m-bus. COM5 [VCP0] selected Device: Alcatel-E101 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! This is how far i get. |
Vodafone 125 Restart Problem Solved By Infinity | zeel_zeel | Infinity-Box | 4 | 07-23-2010 08:25 |
i need firmware for cp150 permanently blocked... [SOLVING] | mawxep03 | FuriousGold | 23 | 12-29-2009 17:02 |
very very easy unlock zte225 with blocked counter by infinity box | genci titi 2002 | Infinity-Box | 2 | 11-28-2008 17:21 |
ZTC 6618 hung solved by infinity | tahod | Infinity-Box | 2 | 09-23-2008 23:17 |
simlock counter blocked solved by mec | patric | MT-BOX | 0 | 04-06-2007 09:01 |
