06-03-2010, 13:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: ludhiana
Member: 818717 Status: Offline Sonork: [email protected] Thanks Meter: 81 | micromax q3 user code and format user area not supported i have three phone of micromax q3 which are failed during user code format user area plz suggest some solution here is log COM3 [VCP0] selected module v3.14 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard fast ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001A03:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01007E00260003:0AEA0000000000 flash: AMD/Fujitsu std [T 00FFx020000 0004x008000] 32Mb otp offset: 01FE0000 detecting chip #01 in region #00... flash: 01007E00260003:0AEA0000000000 flash: AMD/Fujitsu std [T 00FFx020000 0004x008000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01007E00260003:0AEA0000000000 flash: AMD/Fujitsu std [T 00FFx020000 0004x008000] 32Mb otp offset: 01FE0000 detecting chip #01 in region #00... flash: 01007E00260003:0AEA0000000000 flash: AMD/Fujitsu std [T 00FFx020000 0004x008000] 32Mb otp offset: 01FE0000 it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.A53E5732.[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-2_MP_SP18_INDIA_V2.BIN_B87D228D].rpl rom info detection finished ==================== New firmware detected (v.3.14, database date: 28.05.2010): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-2_MP_SP18_INDIA_V2.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: A53E5732 rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-2_MP_SP18_INDIA_V2.BIN project-id: E502-2.MP.SP18.INDIA.V2, 8D227DB8 code offset: 00020000 ffs offset/size [01]: 01200000/00E00000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01200000 standard ffs/eeprom offset confirmed: 01200000 detecting ffs/eeprom size... ffs/eeprom size: 00E00000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01200000-01FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... ........................................... ffs/eeprom: detect standard location pass #1... .................................................. ...................... ffs/eeprom: detect extended location pass #1... .................................................. ........... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01007E00260003:0AEA0000000000 Backup required data Done ====> Patch required data ... .................................................. ........... lock area found Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01007E00260003:0AEA0000000000 flash: 01007E00260003:0AEA0000000000 Write: lock-area-1 error: no any expected answer error: flash write error: 00F60000:00002000 |
06-05-2010, 06:05 | #3 (permalink) |
Member: 818717 Status: Offline Sonork: [email protected] Thanks Meter: 81 | yes sir i have infinity pinfinder that i am using |
06-05-2010, 08:48 | #4 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 47
Member: 88402 Status: Offline Thanks Meter: 489 | Dear sir, i also try micromax q3 user lock but not ok in infinity pinfinder and also spiderman as a interface and also open mobile and solder the rx and tx directly.i enclose log.please correct that in future update thank u. COM12 [VCP0] selected module v3.14 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7603:000E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: E500.PR.R0.1_ID_V10 Version: TINNO25_08A_GEMINI_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 910xxxxxxxxxxx connection Ok detecting structure #1... 0 2 3 4 7 9 12 13 14 15 16 18 19 20 23 25 28 29 30 31error: detection failed (20 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 23 sec Remove/Install battery now ! |
06-05-2010, 09:12 | #5 (permalink) |
Member: 88402 Status: Offline Thanks Meter: 489 | Dear sir, phone user code reset by unlock standard method but take time thats all very thanks to infinity team. COM12 [VCP0] selected module v3.14 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "user code" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:7603:000E status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E223C2200:0AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 02000000 usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_PR_R 0_1_ID_V10.BIN project-id: E500.PR.R0.1_ID_V10, 00000000 code offset: 00010000 ffs offset/size [01]: 01000000/00FF0000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 01000000 standard ffs/eeprom offset confirmed: 01000000 detecting ffs/eeprom size... ffs/eeprom size: 01000000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:01000000-01FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... .......................................... ffs/eeprom: detect standard location pass #1... .................................................. .............. ffs/eeprom: detect extended location pass #1... .................................................. ......... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_PR_R 0_1_ID_V10__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\TINNO25_08A_GEMIN I_PCB01_GPRS_MT6225_S00.E500_PR_R0_1_ID_V10__ffs_2 0100605-010555.B0E.bin flash: 01227E223C2200:0AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E223C2200:0AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 16 min 35 sec Remove/Install battery now ! |
The Following User Says Thank You to cgsm For This Useful Post: |
06-05-2010, 09:39 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @cgsm we will try to improve Q3 operations in next software update @rishi1985 quite strange flash chip type detected. try to make "read code" operation and post here operation log |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
