09-26-2008, 18:13 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | E551_V2.2_Flash File Pls.. i need flash file.. not exist on suport area... E551_C8TURKISH_E551_GPRS_MT6226_S01.00_5.BIN E551_C8TURKISH.00.5, 22948985 detailed information... pls check sir.. Code: COM2 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:B2FE:F7EF high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 damaged, recalculation required identification#1 detection finished device-id: B007F020 identification#1 protocol ver: 04 ver. sw1: E551_C8TURKISH_E551_GPRS_MT6226_S01.00_5.BIN ver. sw2: E551_C8TURKISH.00.5, 22948985 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00800000 ffs chip: 00 eeprom/ffs area: 00000000:00800000-00FFFFFF detecting ffs structure pass 1... ................... detect standard fat location pass #1... ................................ detect extended fat location pass #1... ................................ fat location can't be detected ffs element #1 detection failed detecting ffs structure pass 2... ................... detect standard fat location pass #1... ................................ detect extended fat location pass #1... ................................ fat location can't be detected ffs element #2 detection failed Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 231 sec Remove/Install battery now ! |
Give me a file ....... Pls non ruim to rim file | @@@___@@@ | Various CDMA/TDMA Cell Phones | 3 | 11-24-2009 17:59 |
need flash file for bleu 351x also eprom file pls | arifksarmali | Infinity-Box | 1 | 06-27-2009 09:05 |
pls i need flash files pls. | macsonugoh | Sony Ericsson Hardware Repair | 5 | 05-26-2007 06:42 |
