02-05-2010, 09:44 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | E66 another flashing done module v3.08 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware E66_L2SM_PCB01_GPRS_MT6225_S00.E66_L2SM_V00_QVGA_B T_FM__Nokia-E66_16m_En_Ru_Fr_Es_Id_Th_Vn_Tr_Farsi_Pt_Ar.B0M.bi n skip: Customization/Language Pack skip: Customization write: Eeprom/ffs E66_DUAL_PCB01_GPRS_MT6225_S00.E66_DUAL_V_1_0__NOK IA-E66-1_ffs_01.B0E.bin ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5203:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.F4E1F42C.[E66_DUAL_PCB01_GPRS_MT6225_S00.E66_DUAL_V_1_0.BIN_ F3F0BF14].rpl rom info detection finished device-id: F4E1F42C rom info ver: 05 sw version: E66_DUAL_PCB01_GPRS_MT6225_S00.E66_DUAL_V_1_0.BIN project-id: E66_DUAL_V_1_0, 14BFF0F3 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Code CRC check error fix... firmware do not have "Code CRC check error" area Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\E 66_DUAL_PCB01_GPRS_MT6225_S00.E66_DUAL_V_1_0__syst em_log_F4E1F42C_F3F0BF14_20100205-162717.B0X.bin Area: Firmware flash: EC257E25082501:18E59F00000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:18E59F00000000 Write: Eeprom/ffs sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\E 66_DUAL_PCB01_GPRS_MT6225_S00.E66_DUAL_V_1_0__syst em_log_F4E1F42C_F3F0BF14_20100205-163716.B0X.bin Finished, time used: 10 min 33 sec Remove/Install battery now ! REPAIR SECURITY AREA COM8 selected module v3.08 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:5203:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.F4E1F42C.[E66_L2SM_PCB01_GPRS_MT6225_S00.E66_L2SM_V00_QVGA_B T_FM.BIN_59681873].rpl rom info detection finished device-id: F4E1F42C rom info ver: 04 sw version: E66_L2SM_PCB01_GPRS_MT6225_S00.E66_L2SM_V00_QVGA_B T_FM.BIN project-id: E66_L2SM_V00_QVGA_BT_FM, 73186859 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... . search sec info#1 finished error: incorrect ffs address range file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ system_log_F4E1F42C_59681873_20100205-164337.B0X.bin Finished, time used: 1 min 25 sec Remove/Install battery now ! |
The Following User Says Thank You to lilong_lee For This Useful Post: |
02-06-2010, 01:07 | #3 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 240988 Status: Offline Thanks Meter: 45 | nokia E66 Chinese Flash here is your flash file http://www.zshare.net/download/7220167703ebb6c5/ i have testet working success |
The Following 2 Users Say Thank You to agimsopa For This Useful Post: |
02-06-2010, 23:34 | #5 (permalink) | |
Member: 240988 Status: Offline Thanks Meter: 45 | Quote:
E66 Chinese Flash here is your flash file http://www.zshare.net/download/7220167703ebb6c5/ http://rapidshare.de/files/49114556/E66.rar.html i have testet working success | |
NEW SECURITY (RESPIN) W200 flash Done !! | mbiborna | SETool2 | 0 | 03-29-2010 13:54 |
another N96 done | hasnain | Universalbox | 1 | 12-15-2008 21:22 |
another z170 done well with US | zinoubinabil | Ultimate-Sam | 5 | 09-10-2008 10:53 |
