07-29-2009, 04:05 | #1 (permalink) |
Crazy Poster Join Date: Nov 2006
Member: 395785 Status: Offline Thanks Meter: 20 | E71i DEAD TO HELP WITH TRYING TO REPAIR WITH FULL COPY OF FLASH Help infinity team E71i have died while trying to flash with a flash back of another mobile or reference the same copy of the receiving mobile ==== log: [28/07/2009 09:16:15 p.m.] ==== COM3 [VCP0] selected module v2.85 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active security area recalculation disabled write: Firmware K209M00_PCB01_GPRS_MT6225_S00.M_RK2090405_M28202_V 1_5_0_0M0514__fullflash_20090728-202056.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot Off chip: 0001:9403:0002 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished ffs address can not be detected, value from database assigned: 00000000/00000001 detect device identification#2... detection phase #1... . detect device identification#2 finished Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 Write Fail Finished, time used: 303 sec |
07-29-2009, 20:38 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we will fix this bug in next CHinese Miracle module which will be released tomorrow. you can also use some older CM, for example 2,84 |
07-30-2009, 01:58 | #3 (permalink) |
Member: 395785 Status: Offline Thanks Meter: 20 | With the new version 2.86 I get the same error writing Tion problem is the motherboard of the mobile? ==== log: [29/07/2009 07:20:04 a.m.] ==== COM3 [VCP0] selected module v2.86 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection disabled Action: write NOR flash "smart write" active write: Firmware K209M00_PCB01_GPRS_MT6225_S00.M_RK2090405_M28202_V 1_5_0_0M0514__fullflash_20090728-202056.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot Off chip: 0001:9403:0002 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... slowest Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb Warning: probably flash chip is empty, erased, incorrectly flashed or damaged ! What to do: 1. go to software "Settings" page 2. set "Advanced chip detection method" box CHECKED ! 3. make flash write operation If still no luck: send mail to support ([email protected]) with detailed description of problem, attach the next files in your e-mail: 1. C:\Archivos de programa\InfinityBox\ChineseMiracle\operation.log 2. C:\Archivos de programa\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx. bin detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST M30L0R7000T0, M36L0R7040T0 T 16Mb it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00F40000 Detected ffs/eeprom address is non-standard: 00F40000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00F40000 detecting ffs/eeprom size... ffs/eeprom size: 000C0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00F40000-00FFFFFF detect device identification#2... detection phase #1... . detect device identification#2 finished Check firmware integrity Done Check firmware content ... detecting firmware version... .................................................. .............. .................................................. .............. done warning: can not detect firmware version if software not respond/freez: make "Find firmware version (slow process)" unchecked and repeat operation. detecting firmware build... .................................................. ..... firmware build: 200906201328 detecting product-id... .................................................. .............. done detecting languages... ............................................. language parameters detected detected languages: En Fr Es It Tr Farsi Pt Ar Check firmware content Done Backup required data ... reading: _ffs... file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\_ffs_20090729-073031.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished ffs address can not be detected, value from database assigned: 00F40000/000C0000 detect device identification#2... detection phase #1... . detect device identification#2 finished security area (code #1) check... security area (code #1) fixed detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: 2088C4FFFFFFFF:2088C400000000 Write: Firmware error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 detect device identification#2 finished Write Fail Finished, time used: 892 sec Remove/Install battery now ! |
Zte a712 copy of flash for support !!! | bachatia | Infinity-Box | 2 | 04-02-2010 03:34 |
Help, When trying to Flash/Read Lobster S621,... | GSMAlleyWay | Infinity-Box | 16 | 03-19-2009 19:06 |
HELP PLEASE Trying to Unlock K800i with D-Client | nathank800i | D-Unlock Suite | 6 | 04-10-2008 14:42 |
HELP ME! - Trying to flash 6280 | gennyl | Nokia Base Band 5 ( BB-5 ) | 1 | 09-09-2007 10:37 |
Plss help , I tried to change imei with wintesla on 5110 5.22 , now ... | Nec | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-11-2000 23:26 |
