e88 cpu MT346C can not rebuild imei-why? i think infinity not support cpu MT346C. tried an error as below COM3 [VCP0] selected module v3.07 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 37 sec Remove/Install battery now ! help me thank u |
hello! this isnt IMEI rebuilding LOG. format is not supported yet |
COM3 [VCP0] selected module v3.07 Action: "repair imei" imei write method: mode-2 imei write channel: imei #1 for dual sim/mono CPU new imei: 353243013503445 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [346C:0001]... CPU: MT346C high speed boot On error: hardware is not supported: [0000346C:00000001] Can not initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method error: operation failed ! Finished, time used: 22 sec Remove/Install battery now ! help me thank u |
Hello use new update software 3.22 & Select NAND type cpu then post here result..... |
still no result. not supported!!! |
hello! it is supported as NAND only for flash reading. |
Hello i also change imei MT6253..... Action: "repair imei" Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 358688000000158 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 359212031478348 verification Ok Finished, time used: 3 sec Remove/Install battery now ! ================================================= Action: "repair imei" Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 358688000000158 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 359212031428335 verification Ok Finished, time used: 3 sec Remove/Install battery now ! |
hello guys! yes, IMEI and flash reading. all other functions will be added nearest time |
