E90 infenion e-gold Help.. nokia e90 PHONE condition hang on start up logo.. how to format this phone or can i flash this phone what fw..? PMB-infenion e-gold software version: 1.17 cable type: 1x20 (L20A) platform: PMB: Infineon e-gold searching adapter at COM5... adapter found, version: 2000 pins: 20, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold (820000) result: Rx:4 Tx:5 time required: 26 sec Power On ! reset failed COM5 [VCP0] selected module v1.60 Device: LG-KG375 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG375_eeprom-static_20090404-120612.B1E.bin loading data... data loaded imei: ےےےےےےےےےےےےےےےےے reading eeprom-security_ےےےےےےےےےےےےےےےےے... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG375_eeprom-security_ےےےےےےےےےےےےےےےےے_20090404-120614.B1E.bin reading eeprom-complete_ےےےےےےےےےےےےےےےےے... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG375_eeprom-complete_ےےےےےےےےےےےےےےےےے_20090404-120621.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... error: set erase range error: set erase range error: reset failed Write Failed Finished, time used: 32 sec Remove/Install battery now ! HERES MY READ OUT .. http://rapidshare.de/files/46517531/...4.B1X.bin.html |
hello! we will check your file, but cant promice. only backups from good working phones are needed for processing |
thanks sir...hoping... |
any news for this?.............. do you have file..sir? |
hello! can you get same WORKING backup from this phone? |
no sir my readout came from hanging phone... |
hello! probably you can borrow this phone somewhere on local market? just for few minutes, to read out working backup? |
THERE is no same e90 model here sir only one...... so if you have please give it to me or try to check my readout..thanks |
hello! try different infenion based models, with each try to read out full flash. here is little examples: http:///vbb/showthread.php?t=577622 http:///vbb/showthread.php?t=611045 |
