ELLE N3 pinout wanted Can anypody post right picture pinout for alcatel ELLE N3 please thanx |
What is your phone connector type ? What pinout you already tried to use ? |
Phone conections is like C701. Meabe I dont have luck but all conection solution already tryed.Phone is not dead,it show only beginn screen and power off. |
Hello, You can see correct pinout for this phone in Infinity-Box Shell. Double check that you have used 2x5 connector. If phone still can not be connected you need to open phone and check it's connector hardware. |
No I can not see pinout in shell. And I dont have cabel,I solder 3 vires direkt to cable connector on phone. |
Hello, Pinout is the same as Alcatel-C701. If phone can not be connected try to swap Rx <-> Tx wires |
Thanx for your quickly answers,but is not same.Already tryed to swap rx-tx,gnd of tx place,gnd of rx place,....,....no succes.I will open phone now to check inside. |
SOLVED Pinout is like c852 alcatel but in soft must be rts an dtr unchecked. Thanx for help |
Please, post here pinout that you have used. RTS/DTR: this two boxes affect to several cables only (cables with COM port power) and not affect to RJ45 Infinity-Box cables |
