eMMC write protected Hello Bros is there any known solution for this? [code] Operation : HW Test [ v1.45 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 574 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 4B0001154D5658355A5601420D5108C6 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX5 [eMMC] : FLASH_CID : 1501004B3558564D4201565AC608510D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 2A3BAF2E340B9F84F1949BAC5BF8EABC INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 4148 mV [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BMVX5 , 0xE9000000 , 3728 MiB [eMMC] : CID : 1501004B3558564D4201565AC608510D [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! /code] write protected emmc |
Hello. Only change. Repair over some boxes for Samsung Factory Reset - just a delay, not a cure. |
Would like to give those boxes a try, any special suggestion? Enviado desde mi SM-N920T mediante Tapatalk |
I can't say anything, because not use them. Also there is not much emmc boxes now. Have own things for do that on my work. |
Ok. You are a genius. I will see if RIFF box has something. Enviado desde mi SM-N920T mediante Tapatalk |
