this erro can slved with infinity-box fone restart after this operatinoCOM14 [VCP3] selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0B03:000D boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: MTK25_GEMINI_PCB01_GPRS_MT6225_S00.A522-ZSPIDER_8G-2_G-CAM_MY_146_081014.BIN ver. sw 2: A522-ZSPIDER_8G-2_G-CAM_MY_146_081014, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[MTK25_GEMINI_PCB01_GPRS_MT6225_S00.A522-ZSPIDER_8G-2_G-CAM_MY_146_081014.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[MTK25_GEMINI_PCB01_GPRS_MT6225_S00.A522-ZSPIDER_8G-2_G-CAM_MY_146_081014.BIN]_20081213-185948.B0E.bin flash: EC257E25082501:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: EC257E25082501:18E59F00000000 Finalization Done Finished, time used: 184 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
COM14 [VCP3] selected module v2.70 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0B03:000D Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: A522-ZSPIDER_8G-2_G-CAM_MY_146_081014 Version: MTK25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 136 warning: wrong packet cs warning: wrong packet cs items cleared: 136 of 136 building list... done items remains: 0 Finished, time used: 22 sec Remove/Install battery now ! |
COM14 [VCP3] selected module v2.70 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0B03:000D Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: A522-ZSPIDER_8G-2_G-CAM_MY_146_081014 Version: MTK25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #1... 0warning: wrong packet cs 1 5 8 9 10 12 13 14 15 16 20 23 24 25 27 28 29error: detection failed (18 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 16 sec Remove/Install battery now ! |
COM14 [VCP3] selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-1) Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0B03:000D boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: MTK25_GEMINI_PCB01_GPRS_MT6225_S00.A522-ZSPIDER_8G-2_G-CAM_MY_146_081014.BIN ver. sw 2: A522-ZSPIDER_8G-2_G-CAM_MY_146_081014, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... .................................................. .............. phase #2... .................................................. .............. done error: firmware protection firmware structure #8 is not found What to do: 1. Be sure that your phone really has "bad software" problem, in other case do NOT use "bad software" button ! 2. Repeat "bad software" operation several times to avoid communication problems. 3. Flash phone with firmware from support area and repeat "bad software" operation. If still no luck: 1. read full flash and send to support: [email protected] 2. send "operation.log" file to support: [email protected] error: autodetection failed Finished, time used: 51 sec Remove/Install battery now ! |
COM14 [VCP3] selected module v2.70 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair "bad software" (mode-2) Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:0B03:000D boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18E59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: MTK25_GEMINI_PCB01_GPRS_MT6225_S00.A522-ZSPIDER_8G-2_G-CAM_MY_146_081014.BIN ver. sw 2: A522-ZSPIDER_8G-2_G-CAM_MY_146_081014, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting firmware protection... detecting firmware structure #8... phase #1... .................................................. .............. phase #2... .................................................. .............. done error: firmware protection firmware structure #8 is not found What to do: 1. Be sure that your phone really has "bad software" problem, in other case do NOT use "bad software" button ! 2. Repeat "bad software" operation several times to avoid communication problems. 3. Flash phone with firmware from support area and repeat "bad software" operation. If still no luck: 1. read full flash and send to support: [email protected] 2. send "operation.log" file to support: [email protected] error: autodetection failed Finished, time used: 51 sec Remove/Install battery now ! |
hello! what is phone current condition? restarting? if all you did returned zero result- now flashing must be performaed. sad thing is that we dont have this firmware in our support area collection. can you find same working phone on local market? readed from it backup would fix your faulty phone |
NO NO my problem not for flash becuse i flash phone with another flash for good fone and maked format unlock >>>????? but fone restart and that not one fone have same problem MTK25_GEMINI_PCB01_GPRS_MT6225_S00.A522-ZSPIDER_8G-2_G-CAM_MY_146_081014.BIN this name have problem and maked format with spederman not sloved |
Can you please be more detailed about your problem? You said phone restarts, but you didn't told that how or when. Phone restart when making calls? OR somewhere else? |
hello! please send to us backup readed from same working phone. after we will process it- you will be able to reapir faulty phone. |
