01-20-2016, 18:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND GTAB Was working well customer wanted to upgrade firmware version from 4.4.2.but After flash erase i face this error at start of flashing process ANY ASSISTANCE TEAM BECAUSE TAB NOW DEAD READ INFO Code: Operation : Check / Read Info [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 20010053414D3038473A0F0115031229 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0020 , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , G80MA [eMMC] : FLASH_CID : 20010053414D3038473A0F0115031229 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001CC580000 [eMMC] : FLASH_UCP : 7365 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TY0706-3G-HD-1 ProdName : wsvga ProdModel : P7072G Device : wsvga AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_1_wg_n EXTRA : LCD [0] : gaoqing_lcm_wsvgalnl LCD Res : 600x1024 TOUCH [0] : gaoqing_gsl3680 CAM [0] : gc0308_yuv CAM [1] : gc0329_yuv CAM [2] : gc0311_yuv CAM [3] : siv121du_yuv CAM [4] : gc0309_yuv CAM [5] : gc2035_yuv CAM [6] : gc0328_yuv CAM [7] : hi704_yuv CAM [8] : gc2155_yuv CAM [9] : gc0312_yuv CAM [10] : gc2145_yuv CAM [11] : gt2005_yuv MODEM : yuanda72_wet_jb3_hspa LOCALE : en_US zh_CN es_ES zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT ms_MY vi_VN ar_EG th_TH pt_PT in_ID nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB fa_IR Done! Elapsed: 00:00:12 Reconnect Power/Cable! READFLASH Code: Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 20010053414D3038473A0F0115031229 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0020 , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , G80MA [eMMC] : FLASH_CID : 20010053414D3038473A0F0115031229 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001CC580000 [eMMC] : FLASH_UCP : 7365 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Init HSUSB Ok! Brand : TY0706-3G-HD-1 ProdName : wsvga ProdModel : P7072G Device : wsvga AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1 [Read Ok] : preloader_wsvga.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / wsvga / EMMC FW Size : 755 MiB Scatter saved to : D:\ANDROID FLASHFILES\MT6572__TY0706-3G-HD-1__P7072G__wsvga__4.4.2__ALPS.KK1.MP7.V1\ All done! Code: Operation : Read NVRAM [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 20010053414D3038473A0F0115031229 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0020 , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , G80MA [eMMC] : FLASH_CID : 20010053414D3038473A0F0115031229 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001CC580000 [eMMC] : FLASH_UCP : 7365 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_1_wg_n Read Ok, MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_1_wg_n_eMMC.spnv saved Done! Code: Operation : Flash Erase [ v1.40 ] User accepted Flash Erase operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 20010053414D3038473A0F0115031229 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0020 , OEM : 0100 [eMMC] : FLASH_INF : [NOT_IN_BASE] , G80MA [eMMC] : FLASH_CID : 20010053414D3038473A0F0115031229 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001CC580000 [eMMC] : FLASH_UCP : 7365 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Erase Flash now ... Keep Preloader alive Flash erase done Done! Elapsed: 00:00:34 Reconnect Power/Cable Code: Scatter Load Ok , BaseBand : MT6572 , Project : wsvga , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Start at : [20/01/2016 / 14:53:30] Operation : Flash [ v1.40 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 20010053414D3038473A0F0115031229 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Finish at : [20/01/2016 / 14:53:52] Last edited by Kirumira; 01-20-2016 at 18:50. Reason: SPELLING |
The Following User Says Thank You to Kirumira For This Useful Post: |
01-20-2016, 19:41 | #4 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, You Could Select Scatter File & Flash It. No Needed To Flash Erase. Now Try To Write This "preloader_wsvga.bin" File Via "Init Preloader" Option On Extra Tab. |
01-20-2016, 19:54 | #6 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, Now You Should Need Correct Preloader Or Good Firmware. |
The Following User Says Thank You to MyGSM World For This Useful Post: |
01-21-2016, 08:32 | #10 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Here is file preloader_wsvga Dear friend what do u mean? be specific. I need your assistance clearly |
01-21-2016, 09:41 | #11 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
but cant say log are looks difrent | |
01-21-2016, 12:57 | #14 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | preloader - Download - 4shared One of them will work. |
01-21-2016, 14:09 | #15 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ES-Brazil
Member: 217679 Status: Offline Thanks Meter: 95 | iphone 6 mt6571 DEAD: Wait for phone... Phone found! [ 20 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00EC00BC00000066005600EC00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x8B DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! |
