06-14-2021, 20:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: AsTeknik Elektronik
Member: 194874 Status: Offline Thanks Meter: 458 | Error : Failed to read initial info! Erased/Damaged or unsupported device??? I kept the keys pressed, it still won't turn on? Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.24 Load IDBase v524190 Ok! UserName and/or Password not set! Can't continue! Update failed! Check settings and/or internet connection! Operation : Read Firmware [ v2.24 ] ExtSparse : Enabled ForceRead : Disabled 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : B957403B25865F47A3EDF8504A7847AA BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : Xiaomi : Helio [G90][A22] | Manual : Disabled BROM : SOCID : 99CD5E4C4E647018F6E2F34D943D427CD78F56C9230E1E1CA4 604D16244A40A3 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Look for cookies BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_V2.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : FireFly EMI : SRC : preloader_k85v1_64.bin EMI : CNT : 0005 EMI : Init EMI from INTERNAL DB EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00080000 [ 512,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] UFS: AD014839485135344145434D4D444152 UFS: VEN : 0x01AD VID : H9HQ54AECMMDAR IFW : A002 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0xEE5800000 [ 59,59 GB ] FSN : 2008d84b6240000000000000 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3EB28F731D72FA2EFA144A3DE45203F DA : USB : HIGH-SPEED Boot done! Error : Failed to read initial info! Erased/Damaged or unsupported device??? >>> Seems as something wrong with device! Check battery charge and device state! Reconnect Power/Cable! |
06-15-2021, 08:17 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | HardReset - 2 side keys + PowerOn during 30-60 seconds will help. It universal. It help always, Booting will not kill anything. Such error represent DRAINED OUT BATTERY or some SW problem. |
06-15-2021, 09:31 | #8 (permalink) | |
Member: 194874 Status: Offline Thanks Meter: 458 | Quote:
As you said, holding down 3 keys, it won't open. That's how it happened yesterday, I came in the morning, probably the battery is still not finished. | |
06-15-2021, 10:04 | #10 (permalink) | |
I tried several times on the old version, no problem. It shows that it is repairing but the serial was not changing. I downloaded the new version 2.24, it was like this on the first try, it didn't open. I just wanted to make a backup of the software inside. (Meanwhile, the device appeared with Xiaomi Redmi Note 10S (Secret) open in pc adb shell. It says cm 2 (rosemary). Which one is right? It shows the DA and PRELOADER information I selected or the device content? ) 2.23 IDENTIFY -------------- Operation : Identify [ v2.23 ] Mode : FLASH 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 CODE : Krug TYPE : MODERN RAPHAEL BROM : MEID : B957403B25865F47A3EDF8504A7847AA BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BROM|BL : 0x05|0xFE BROM : BOOTROM MODE : 0_base : BASE_v2112 | Manual : Enabled BROM : SOCID : 99CD5E4C4E647018F6E2F34D943D427CD78F56C9230E1E1CA4 604D16244A40A3 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F AGENT : Look for suitable BootChain in DA ... AGENT : DA.bin AGENT : Found MT6785 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6752 EMI : SRC : preloader_k85v1_64.bin EMI : CNT : 0005 EMI : [00] : eUFS : LP_DDR4X : DEV : H9HQ15AECMBDAR : RAM : [ 6,00 GB ] EMI : [01] : eUFS : LP_DDR4X : DEV : H9HQ15AFAMBDAR : RAM : [ 8,00 GB ] EMI : [02] : eUFS : LP_DDR4X : DEV : H9HQ54AECMMDAR : RAM : [ 6,00 GB ] EMI : [03] : eUFS : LP_DDR4X : DEV : MT064GASAO2U21 : RAM : [ 6,00 GB ] EMI : [04] : eUFS : LP_DDR4X : DEV : MT128GASAO4U21 : RAM : [ 6,00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00070000 [ 448,00 KB ] DRAM: 0x180000000 [ 6,00 GB ] UFS: AD014839485135344145434D4D444152 UFS: VEN : 0x01AD VID : H9HQ54AECMMDAR IFW : A002 LU0 : 0x00400000 [ 4,00 MB ] LU1 : 0x00400000 [ 4,00 MB ] LU2 : 0xEE5400000 [ 59,58 GB ] FSN : 2008d84b6240000000000000 REG : 0x101010000 CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3EB28F731D72FA2EFA144A3DE45203F DA : USB : HIGH-SPEED Boot done! Product Brand : Redmi Product Device : rosemary Product Model : rosemary Product Name : rosemary Patch Level : RP1A.200720.011 Display ID : RP1A.200720.011 Ver. CodeName : REL Ver. Release : 11 Sec. Patch : 2021-04-01 Build Time : 15.04.2021 Product Info : rosemary Product Manfct : Xiaomi Product Board : rosemary Board Platform : mt6785 NVRAM check : Failed! NVRAM damaged! NVRAM : SEC SIGNED [ IMEI RSA SIGNED ] Backup sensetive data [ 14 ] Backup path : Backup\MT6785__3EB28F7301D72FA2EFA144A3DE45203F\ [44] Read : NVRAM [13] Read : NVDATA [42] Read : PROINFO [12] Read : NVCFG [23] Read : PROTECT1 [24] Read : PROTECT2 [22] Read : PERSIST [0] Read : PRELOADER [25] Read : SECCFG Backup done! STORAGE : LifeStatus : UFS : OK! Done! Elapsed: 00:00:33 REPAIR SECURITY ----------------- Operation : Repair Security [ v2.23 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM4) MODE : BOOTROM PORT : 4 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6785 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : MEID : B957403B25865F47A3EDF8504A7847AA BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+EXT BROM : BOOTROM BROM : LOG : F0: 102B 0000 F3: 1001 0000 [0200] F3: 1001 0000 F7: 0000 0000 V0: 0000 0000 [0001] BROM : SOCID : 99CD5E4C4E647018F6E2F34D943D427CD78F56C9230E1E1CA4 604D16244A40A3 BROM : SLA : Local Auth BROM : SLA : Auth Started! BROM : SLA : Auth Passed! BROM : SLA : 0x0000001F BROM : Configuring target for META BROM : META configured! INIT : META confirmed! Boot done! AP_CHIP : MT6785 AP_SWTM : Fri Apr 16 00:32:55 CST 2021 AP_DSPP : global AP_SWVR : alps-mp-r0.mp1.tc8sp3-mt6785-V1.10_lcsh.xm.r0mp1.k69v1.64_P41 MD_CHIP : MT6785 MD_SWTM : 2000.00.00 MD_DSPV : 1.0 MD_DSPP : MOLY.LR13.R1.MP.V89.5.P30 MD_SWVR : LCSH_XM_R0MP1_MT6785_SP_HW MD_HWVR : Unknown IMEI[0] : 86XX IMEI[1] : 86XX IMEI[1] : 35XX Item : update Ok! Done! Elapsed: 00:01:01 Reconnect Power/Cable! | |
06-15-2021, 10:52 | #12 (permalink) | |
This is the previous diary. The phone was working, I said read firmware 2.24, then it happened. It has nothing to do with nvram. just arrived redmi 9a arrived, the room caused a problem. I installed 2.23, I think this version is troublesome. | |
06-15-2021, 17:22 | #14 (permalink) |
Member: 194874 Status: Offline Thanks Meter: 458 | [QUOTE=JayDi;14410871]It is not related to version at all. There is always chance per 100 phones get 3-5 problematic ones.[/QUOTE can you help me find the firmware? I found "ROSEMARY". Is there a place where I can find "SECRET"? the phone did not turn on. It's interesting to be this way. rosemary_global_images_V12.5.5.0.RKLMIXM_20210421. 0000.00_11.0_global_379afb5b91.gz secret_global_images_V12.5.5.0.RKLMIXM_20210421.00 00.00_11.0_global_379afb5b91.tgz |
