12-06-2007, 12:07 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: MA
Member: 52763 Status: Offline Thanks Meter: 35 | Error n95 with mini usb pin 5 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active error: boot initialization step-2 failed: error: boot initialization step-3 failed: error: boot initialization step-3 failed: error: boot initialization step-2 failed: error: boot initialization step-2 failed: error: boot initialization step-2 failed: 9600 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 9 sec Remove/Install battery now ! |
12-07-2007, 00:21 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello djamel852! as long as phone is disassembled- please check 2 things: 1. is it really usb 5 pin or maybe it is 2x5? you can check that by counting connector pins soldered to PCB. if there is only 5 pins- it is 5pin, if 10pins- 2x5. 2. maybe there is marked test points tx, rx ? |
12-07-2007, 07:13 | #8 (permalink) | |
bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 | |
12-07-2007, 16:47 | #13 (permalink) |
Member: 52763 Status: Offline Thanks Meter: 35 | ihave find rx and tx COM26 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:1E52:A1F4 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 Ok security area backup saved: id.D5C23AAA.[T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V0917A .BIN_01BA0E6D].rpl identification#1 detection finished device-id: D5C23AAA identification#1 protocol ver: 04 ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.B10_EFATRIS_V0917A .BIN ver. sw2: B10_EFATRIS_V0917A ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok file saved: backup_system_log_D5C23AAA_T6226_05C_PCB01_GPRS_MT 6226_S01.B10_EFATRIS_V0917A.BIN_01BA0E6D_20071207-182839.B0X.bin Finished, time used: 125 sec Remove/Install battery now ! |
12-07-2007, 16:56 | #14 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | that is nice bro ...... now u should post pinouts there ...... in order to other ppz get help from this .. Good test report keep working GOOD.. |
12-07-2007, 18:16 | #15 (permalink) |
Member: 52763 Status: Offline Thanks Meter: 35 | jack headset 3.5 mm COM26 selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6226:8A02:8A01]... chip: 0031:1E52:A1F4 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: B10_EFATRIS_V0917A Version: detecting structure #2... done imei: 44528071000305 connection Ok building list... done items to clear: 185 166 of 185 items cleared building list... done 0 items remains Finished, time used: 123 sec Remove/Install battery now ! |
Microbox Mini USB pin out | drancill | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 06-30-2009 11:36 |
help...5 pin mini usb pin out schematic | tio dan bilqis | Infinity-Box | 2 | 07-13-2008 21:40 |
need pinout n95 with mini usb pin5 like motorolla v3 | titan_wonder | Infinity-Box | 1 | 11-17-2007 20:57 |
Help with mini usb on fbus with uid | Roughrider202 | Nokia Base Band 5 ( BB-5 ) | 3 | 09-08-2007 15:51 |
i can,t connect with mini usb port | pnm_12000 | Smart-Clip | 6 | 07-25-2007 23:12 |
