08-04-2020, 10:46 | #1 (permalink) |
Freak Poster Join Date: Sep 2019 Location: Mozambique
Member: 2927861 Status: Offline Thanks Meter: 47 | CM2SPD2 and CM2MTK2 are the best tools |
08-04-2020, 10:48 | #2 (permalink) |
Member: 2927861 Status: Offline Thanks Meter: 47 | CM2SPD2 and CM2MTK2 are the best tools since I use the infinity dongle. I am having problems running the CM2SPD2 and CM2MTK2 modules. every time i want to run these modules i have to uninstall and reinstall it again. the modules do not open. and there is no fault.bin file. it does not help to say that you send the fault.bin file because in the module directories there is no file with this name. |
08-04-2020, 14:50 | #3 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Use Free antivirus to cure your PC: Dr. Web CureIT https://free.drweb.com/download+cureit+free/?lng=en result ? | |
08-04-2020, 14:50 | #4 (permalink) | |
08-04-2020, 17:07 | #5 (permalink) |
Member: 2927861 Status: Offline Thanks Meter: 47 | I formatted my hd and installed windows 7. I installed the modules cmespd2 and cm2mtk2. When I finished installing the modules I tried to explain all of them well. but when I restarted the pc to be able to perform the text. the modules did not open again. NB: I formatted my HD completely and installed the w7 system. in order to rotate the infinity modules just yet, the problem still remains. I ask for a definitive solution because this has nothing to do with viruses, antiviruses. or fault.bin file. help. |
08-04-2020, 22:25 | #6 (permalink) | |
If you can not run software 2nd time this means that installation files become damaged or you put wrong files to software folder or something like that. You must use default installation path ! Now you must answer 1. have you tested your PC with free antivirus software ? What is the result ? 2. Do you have fault.bin file in folder with software ? 3. What is the installed version of CM2MT2 ? 4. What new files do you see in folder with software after run ? 5. What is the installation folder ? Last edited by InfinityHelp; 08-04-2020 at 22:46. | |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
08-05-2020, 18:55 | #7 (permalink) |
Member: 2927861 Status: Offline Thanks Meter: 47 | Error not open the CM2SPD2 & CM2MTK3 since I use the infinity dongle. I am having problems running the CM2SPD2 and CM2MTK2 modules. every time i want to run these modules i have to uninstall and reinstall it again. the modules do not open. and there is no fault.bin file. it does not help to say that you send the fault.bin file because in the module directories there is no file with this name. I formatted my hd and installed windows 7. I installed the modules cmespd2 and cm2mtk2. When I finished installing the modules I tried to open all of them was open well. but when I restarted the pc the modules did not open again. NB: I formatted my HD completely and installed the w7 system. in order to rotate the infinity modules just yet, the problem still remains. I ask for a definitive solution because this has nothing to do with viruses, antiviruses. or fault.bin file. |
08-05-2020, 19:20 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | How are you ? How is the weather today ? Is it really hot or not so ? Why do you ignore advice that supporters gives you many times ? Please do not ignore our advices and read instruction here https://forum.gsmhosting.com/vbb/f29...tools-2881406/ and here https://forum.gsmhosting.com/vbb/f29...tools-2881407/ Waiting for your kind answers ! Please do not send e-mails to support any more. Thank you for your kind understanding and cooperation ! |
08-05-2020, 19:53 | #9 (permalink) | |
Member: 2927861 Status: Offline Thanks Meter: 47 | Quote:
sorry if i was aggressive in words. if i am being so persistent, it is me months ago i had already asked for a help request related to this issue and i already followed all the instructions that the supporters of infinity have left in the forum. the problem still continues. if possible i will send a video shown what is happening on my pc. | |
08-05-2020, 22:43 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | You must post here answers to questions ! Questions are here: https://forum.gsmhosting.com/vbb/f29...tools-2881406/ and here https://forum.gsmhosting.com/vbb/f29...tools-2881407/ |
08-06-2020, 06:56 | #12 (permalink) | |
ok i will do that, after following all the instructions in the topic. | |
08-06-2020, 12:03 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | ok dear friend. I am sure you can fix your PC easily, you can remove viruses, you are experienced man ! Anyway let me save your time and repeat questions here, this helps you to avoid many clicks to different links and save your time with repeated reading. 1. have you tested your PC with free antivirus software ? https://free.drweb.com/download+cureit+free/?lng=en What is the result ? 2. Do you have fault.bin file in folder with software ? 3. What is the installed version of CM2MT2 ? 4. What new files do you see in folder with software after run ? 5. What is the installation folder ? please answer us also the same way, with numbers from 1. to 5. This kind of cooperation helps us to srvre your better and faster ! |
08-06-2020, 18:57 | #14 (permalink) | |
greetings. ok i will execute the instructions left that upon arriving at my work establishment. and then I will let the results I get | |
