Old 03-25-2010, 07:10   #1 (permalink)
Member: 430612
Thanks Meter: 301
i-mobile im6 stuck with tv
COM6 [VCP0] selected
module v3.11
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9503:0003
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.86C51164.[GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.Q5-FKD_06_V1_3_020_091120.BIN_47E8E299].rpl
rom info detection finished
New firmware detected (v.3.11, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 86C51164
rom info ver: 05
sw version: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.Q5-FKD_06_V1_3_020_091120.BIN
project-id: Q5-FKD_06_V1_3_020_091120, 99E2E847
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: GINWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.Q5-FKD_06_V1_3_020_091120__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\GINWAVE25_08A_GEM INI_PCB01_GPRS_MT6225_S00.Q5-FKD_06_V1_3_020_091120__ffs_20100325-080539.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\G INWAVE25_08A_GEMINI_PCB01_GPRS_MT6225_S00.Q5-FKD_06_V1_3_020_091120__system_log_86C51164_47E8E2 99_20100325-080605.B0X.bin
Finished, time used: 5 min 7 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 03-25-2010, 18:03   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
as you can see- we dont have such firmware in our collection, but you can try to search for smthng similar
i-mobile im6 stuck with tv luyanda Infinity-Box 3 03-26-2010 16:17
i-mobile im6 stuck with tv luyanda Chinese Models & Cloned Phones 0 03-25-2010 14:12
Page generated in 0.13688 seconds with 9 queries
