02-26-2009, 08:34 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What cable you have used ? What baudrate you have selected for operation ? I suggest you to post log as text (but not as a picture) so we will be able to see more information about problem. |
02-26-2009, 13:52 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Made In Brazil Age: 42
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | COM9 [Serial2] selected Module v2.77 Device: Autodetect 6205-6227 NOR Checking Data. Wait ... Advanced Detection of Flash Enabled Action: read NOR flash Boot ... Press and hold the Connect button! 19200 fixed Connecting. Wait ... Initializing [6225:8 A03: 8A00] ... CPU: MT6225 Boot In High Speed On chip: 0001:2 D03: 0000 status: FF Startup Package Size: 0400 Release the button to Connect! Boot Done Initializing ... Detecting chip # 00 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Detecting chip # 01 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Detecting chip # 02 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Detecting chip # 03 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Number of Chip Flash / Region detected: 04/01 Done Initialize Determine Speed ... 115200 Determine Speed Done Startup Code Boot ... Code Boot Done Initialize Integrity check the firmware ... Auto detection. Parameters of the Device In Progress ... Detecting chip # 00 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb Detecting chip # 01 in region # 00 ... Flash EC257E25082501: 18E59F00000000 Flash Samsung AMD / Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 Number of Chip Flash / Region detected: 01/01 Total Size of Flash Region: 01000000 detect device identification # 1 ... Detection of phase # 1 ... detect device identification # 1 finished identification # 1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.77, database date: 14.02.2009): E880_JJF2F12TRI_MT6225S00.GM_01_0_20080711.BIN This is missing firmware in support area. If this phone is good and working: - Make "Read FullFlash" operation - Send flash backup files to support: [email protected] - Include in your e-mail full text from phone back label (phone name etc.). ==================== identification # 1 detection finished identification # 1 protocol see: 04 Version 1 SW: E880_JJF2F12TRI_MT6225S00.GM_01_0_20080711.BIN Version 2 SW: E880_JJF2F12TRI.GM.01.0, 00000000 Size / Offset of FFS: 00E00000/00200000 detect device identification # 2 ... Detection of phase # 1 ... . detect device identification # 2 finished Detecting ffs / eeprom area in 1 chip (s) ... standard ffs / eeprom offset detected: 00E00000 Flash EC257E25082501: 18E59F00000000 Checking area [00000000]: 00000000-00FFFFFF ... ffs / eeprom found near: 00E00000 Detecting ffs / eeprom size ... ffs / eeprom size: 00200000 ffs / eeprom chip: 00 ffs / eeprom area: 00000000:00 E00000-00FFFFFF Integrity check the firmware Done Check Contents of Firmware ... Check Contents of Firmware Done Save a copy of data ... Reading flash [E880_JJF2F12TRI_MT6225S00.GM_01_0_20080711.BIN] ... Warning: wrong cs at 0x0003D800, retry ... Warning: wrong cs at 0x0003D800, retry ... Warning: wrong cs at 0x0003D800, retry ... Warning: wrong cs at 0x0003D800, retry ... Warning: wrong cs at 0x0003D800, retry ... Warning: wrong cs at 0x0003D800, retry ... Warning: wrong cs at 0x0003D800, retry ... Warning: wrong cs at 0x0003D800, retry ... Warning: wrong cs at 0x0003D800, retry ... Error: too many retries during read operation Errors likely existed during the operation of reading the Flash. I would repeat the operation? Error: wrong answer: 2A Errors likely existed during the operation of reading the Flash. I would repeat the operation? Warning: wrong cs at 0x00000000, retry ... Warning: wrong cs at 0x00000000, retry ... Warning: wrong cs at 0x00000000, retry ... Warning: wrong cs at 0x00000000, retry ... Warning: wrong cs at 0x00000000, retry ... Warning: wrong cs at 0x00000000, retry ... Warning: wrong cs at 0x00000000, retry ... Warning: wrong cs at 0x00000000, retry ... Warning: wrong cs at 0x00000000, retry ... Error: too many retries during read operation Errors likely existed during the operation of reading the Flash. I would repeat the operation? For User Canceled Finalized. Time Spent: 113 sec Remove / Replace the battery! |
02-26-2009, 15:29 | #4 (permalink) | |
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | Quote:
02-28-2009, 19:40 | #6 (permalink) | |
If you still want to use low-quality Prolific cables you must at least install good drivers: http://www.atm-box.com/index.php?id=utilities | |
error red fullflash | LuisinhoCell | Infinity-Box | 6 | 03-08-2009 22:06 |
sagem error red codes | benali58 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 09-24-2008 23:30 |
u300 unlocked how to red flash | zeroualot_7 | FuriousGold | 1 | 03-05-2007 19:24 |
Need K750i Cid 49 Red Flashing Step By Step | sanjeewa57 | Cruiser Suite | 18 | 10-11-2006 11:01 |
w550i cid 49 red flash sucesfully | idoniletisim | Cruiser Suite | 0 | 05-13-2006 09:59 |
