evry body can give me this frimware??? 1 Attachment(s) hi i need full flash for this model: nokia n100 tv |
hello! please post here phone's info readed by "read detailed information" |
thanks for your reply this set flashed with wrong flash file but it have 2 cpu i need frimware for cpu1 and it is 6225. thanks |
hello! if CPU2 still have original firmware inside- please post it's version by this version we will try to advice firmware for first MCU |
another cpu is 6223 and i cant conect to that by infinity |
hello! this can not be true. you must be using wrong pinout. please tell detailed how it is "not connect" post a log |
i cant conect to 6223 cpu with spiderman box also i solder rx tx on main board and still i cant conect to 6223 cpu |
hello! procedure of connecting with second MCU is following: you press & hold power button first phone will startup (this is first MCU start) you still hold power button and only after some time will boot second MCU. and if you holded power button pressed all the time- you will get connection. on models which i tested sometimes it took time up to 30seconds to make programm detect second MCU. so be patient and keep power button pressed |
thanks for your reply i flashed it with one frimware and now it on but key problem and ... after that i could canect to second cpu and read sw ver on it ver. sw1: LC6223_07A_PCB01_GSM_MT6223_S00.LBN8402_7_12_1_2T0 4M1218_M401A_S.BIN |
hello! you said you flashed some firmware and now set work what version did you flash to your phone? what problem with keys now? |
