Old 02-12-2021, 08:15   #1 (permalink)
Member: 22284
Thanks Meter: 81
Experts need help to Repair imei using CM2MT2
I just messed up my Redmi note 9 (M2003J15SS) RAM 3GB internal storage 64GB MT 6768 Helio 70 Global version MIUI 11.0.4.0 (QJOMIXM)and my two imei numbers are gone but network available ,can't dial out or receive any call and when i type *#06# the only number that comes out is the serial number. How may i repair the Imei using CM2MT2 v2.21
Old 02-13-2021, 08:04   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Make SmartReset for start. It may helps in some cases.
Old 02-13-2021, 18:43   #3 (permalink)
Member: 22284
Thanks Meter: 81
what is this is smart reset can you explain better
Old 02-13-2021, 20:18   #4 (permalink)
silivriserdar's Avatar
Member: 2291790
Thanks Meter: 45
[CENTER][B] Click
Redmi Note 9 Pro cihaz?mdan Tapatalk kullan?larak gönderildi
Old 02-13-2021, 21:27   #5 (permalink)
Member: 22284
Thanks Meter: 81
Sillysiserdar what you Showed me is for redmi note 8 pro not redmi note 9 merlin
Old 02-13-2021, 21:40   #6 (permalink)
Member: 2291790
Thanks Meter: 45
[CENTER][B] Same method
Old 02-13-2021, 22:02   #7 (permalink)
Member: 22284
Thanks Meter: 81
IN NORMAL MODE
Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.21
Load IDBase v210169 Ok!
Update configuration ...
THEN IN META MODE
Update Ok!
Operation : Repair Security [ v2.21 ]
Mode : FLASH
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM10)
MODE : PRELOADER PORT
PORT : 10
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
CODE : Talbot
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000007
BROM : SecMode : SBC+SLA+SDA
BROM : BROM|BL : 0xFF|0x03
BROM : PRELOADER PORT
MODE : Xiaomi : Helio [G70][G80] | Manual : Disabled
BROM : SOCID : 8069D12E31816920532501B6BF72D2485AA520678CF893A41E 06393F6E66C13C
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6768
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00080000 [ 512.00 KB ]
DRAM: 0x100000000 [ 4.00 GB ]
EMMC: 13014E53304A394A38101EB690567731
EMMC: VEN : MICRON | OEM : 4E01 | DEV : S0J9J8
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x01000000 [ 16.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6768 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0001 , EVOL : 0x0000
RNID : 928079F74AF9822DE74E1280887F7998
DA : USB : HIGH-SPEED
Boot done!
Info : Device is not supported yet!
>>> Repeat operation in META mode [ Platform -> Global -> Meta ]
Reconnect Power/Cable!
Old 02-13-2021, 22:03   #8 (permalink)
Member: 22284
Thanks Meter: 81
IN META MODE Operation : Repair Security [ v2.21 ]
Mode : META
PORT : 10
INIT : META confirmed!
Boot done!
AP_CHIP : MT6768
AP_SWTM : Thu May 28 17:58:51 CST 2020
AP_DSPP : merlin[gl]
AP_SWVR : alps-mp-q0.mp1.tc8sp2-V1.9.1_huaqin.q0mp1.k69v1.64_P34
MD_CHIP : MT6768
MD_SWTM : 2000.00.00
MD_DSPV : 1.0
MD_DSPP : MOLY.LR12A.R3.MP.V98.P37
MD_SWVR : HUAQIN_Q0MP1_MT6769_SP_HW
MD_HWVR : Unknown
IMEI[0] : [ ERASED ]
IMEI[1] : [ ERASED ]
IMEI[1] : 8692280520XXXXX
Item : update Failed! [ 0xFFFF ]
Done!
Elapsed: 00:00:52
Old 02-13-2021, 22:03   #9 (permalink)
Member: 2291790
Thanks Meter: 45
IN NORMAL MODE
THEN IN META MODE
Update Ok!
Mode : FLASH
PORT : 10
BROM : Init BROM
BROM init passed!
CODE : Talbot
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
[CENTER][B] Bypass + IMEI Repair
Old 02-13-2021, 22:07   #10 (permalink)
Member: 22284
Thanks Meter: 81
Can you explain better, HOW TO PERFORM THE BYPASS METHOD
Old 02-14-2021, 12:02   #11 (permalink)
JayDi's Avatar
Member: 462970
BROM + sSLA
or
Flash ENG ROM
then repair.
Old 02-14-2021, 13:15   #12 (permalink)
Member: 22284
Thanks Meter: 81
JayDi i would like to go for (BROM +sSLA) what is this and give step by step procedure
Old 02-14-2021, 13:22   #13 (permalink)
Member: 2291790
Thanks Meter: 45
[CENTER][B] 1. Device nvdata and nvram reset.
2. CM2 open platform Main meta click.
3. Brand xiaomi g80
4. IMEI repair security IMEI 2 Write
5. Start device connect
Old 02-14-2021, 13:28   #14 (permalink)
Member: 22284
Thanks Meter: 81
where to get the nvdata and nvram reset. i have another Redmi note 9 Indian version 4GB Ram 64GB storage working while mine is 3GB 64GB storage Global version. Can i use the data from this one ,if yes how do i get the nvdata and ram reset
Old 02-14-2021, 13:40   #15 (permalink)
Member: 2291790
Thanks Meter: 45
[CENTER][B] Nvram ve nvdata reset cm2 Memory Tool nvram ve nvdata erase
Page generated in 0.21078 seconds with 9 queries
