04-30-2021, 14:26 | #24 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | I got the engineering firmware from xda. Link here: ****************************/file/7fs4c...VD171.zip/file Pass: VD171 I flashed the phone Tried to repair imei 2 in meta mode There was no error, all success. But nothing changed Any idea? Enviado desde mi SM-G975U1 mediante Tapatalk |
08-07-2021, 17:43 | #25 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | OK, now tried again, long time waiting for @Jaydi help.. I flashed ENG, repaired imei 2 via meta after wipe nvdata and nvram. OK phone works well on ENG Rom, Imeio Fixed. I then Wrote the Global miui 11 with Safe Erase [Upgrade] option activated. after reboot no imei number in phone, only Serial number and barcode is shown. any suggestion please ? |
08-07-2021, 18:14 | #26 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | BTW if I write back the ENG firmware, the repaired IMEI is there. Also, in the setup screen, in the wifi section, it shows a wifi network with NVRAM_FAILED or something like this, as the Network Name. |
12-03-2021, 05:26 | #29 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | Help repair Imei 1 on redmi note 9 merlin global Has the way been found to repair Imei 1 on redmi note 9 merlin global?, if yes using CM2MT2 may someone explain in details |
