03-22-2019, 09:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Badong's Junkshop
Member: 260632 Status: Offline Thanks Meter: 639 | rda chip after format no power .. Card found : S/N : 5raezak3 , v0137 Chinese Miracle II [RDA module] v 1.05 Operation : Format File System Settings : SmartFormat is On Waiting phone ... Connect battery, press and hold '0' button Connect USB cable and keep hold button, until phone will be detected Init : 18906C02 Settings registers ... 1st boot Ok ==== CPU CPU_ID : 8809 , rev : 4009 CPU_CN : RDA Micro CT , RDA8851X ==== FLASH FL_VEN : 60C8 , rev : 1600 FL_CNM : GigaDevice , GD25Q32 FL_CAP : 00400000 Initial : 81C0024C ==== Booting Sending RamRun Loader ... Set : 8809 , 00400000 Use : 8809_00400000_usb.fp Sending HdrConf ... Sending LdrData ... Loader sent, starting... Flush : 0400F000 Loader run Boot Done! NVMFAT Area : 0x003A0000 , Len : 0x0005C000 Range as Factory Defined Format User Area ... CSD WR : 81C05954 , 81C05968 CSD DR : A2000000 , A2008000 , A2010000 CSD MB : 00008000 Format Done Elapsed: 00:00:23 Reconnect Power/Cable! |
03-22-2019, 09:24 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
latest version is 1.06, Note: Rda chips after format Takes more time to boot up. Insert charger keep pressing power key. | |
The Following User Says Thank You to Kirumira For This Useful Post: |
03-23-2019, 04:45 | #5 (permalink) |
Member: 260632 Status: Offline Thanks Meter: 639 | change battery fully charge press power for 5mins no response still no power , phone connected with charger press for more than 5 mins still not power up br |
