factory file read problem factory file not read bin file ok read br Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:29 Reconnect Power/Cable! Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50305858585810F260339D21AD DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810F260339D21AD [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : samsung ProdName : Galaxy J5 ProdModel : SM-J500H Device : Galaxy J5 AndroidVer: 5.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP2.V1_GIONEE6582.WT.L_P30 [Read Ok] : ebr1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Error] : Bad EXT data Looks like unusable file , break! Read error :( Operation Failed Elapsed: 00:09:10 Reconnect Power/Cable! read bin file Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50305858585810F260339D21AD DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810F260339D21AD [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : samsung ProdName : Galaxy J5 ProdModel : SM-J500H Device : Galaxy J5 AndroidVer: 5.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP2.V1_GIONEE6582.WT.L_P30 Saved to : C:\Users\SUDHEER\Desktop\MT6582__SAMSUNG__SM-J500H__ALPS.L0.MP2.V1_GIONEE6582.WT.L_P30__Android _5.1__07.11.2015.ispff Done! Elapsed: 00:15:52 Reconnect Power/Cable! |
It encrypted phone. You can read FW by next way : 1. Repair ExtData 2. Power On phone 3. Insert USB cable 4. Press "Read FW" button. Phone will off itself and read process will start. |
after Repair ExtData only log |
Read my post again. Try little better write complete words. I have no idea, what mean "only log". |
encryption unsuccessfull only log help me ok set dead |
For Encryption Unsuccessfull do Repair ExtData. Also check your phone with HW Test for RO. Br. Infinity Box Support Team. |
Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50305858585810F260339D21AD DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810F260339D21AD [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : samsung ProdName : Galaxy J5 ProdModel : SM-J500H Device : Galaxy J5 AndroidVer: 5.1 MTKxCPU : MT6582 MTKxPRJ : ALPS.L0.MP2.V1_GIONEE6582.WT.L_P30 [Read Ok] : ebr1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Error] : Bad EXT data Looks like unusable file , break! Read error :( Operation Failed Elapsed: 00:09:12 Reconnect Power/Cable! |
Just answer me - YOU TRYING READ FW FROM DEAD/DAMAGED PHONE??? |
if you correctly says JayDi the points, you can read the firmware |
And yet, the firmware will start reading at the moment, after EXTData, when the mark disappears android inscription ERASE ........ |
Yes, exactly. But this user can't even explain. In first post he just trying, in second - something stuck on logo. |
He just missed the right moment after the android logo |
change the frimware reading tool |
try format / reset setting bro... and check your baterry before read flashfile |
