10-04-2008, 23:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | failed to unlock UT Starcom GPRS 779 here log file: COM5 [VCP1] selected Device: UTstarcom GPRS779 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... error: unknown flash chip: 048A:EA00:3FFD:EA00 error: unknown flash chip: B510:48EF:2280:5014 error: unknown flash chip: 6646:2373:FFFF:FFFF Check Space Fail Finished, time used: 18 sec I read full flash just in case you may need it infinity guys... here log foor flashreading: COM5 [VCP1] selected Device: UTstarcom GPRS779 Checking data, wait... Action: read flash Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... Check Flash Done Check Parameters... part 1 of 3... Reading... file saved: C:\mobilestuff\InfinityBox\VModule\ut_starcom_gprs _479\backup_full_part_1_of_3_20081004-151050.92X.bin part 2 of 3... Reading... error: unexpected rx block size: 0015CA/002000 file saved: C:\mobilestuff\InfinityBox\VModule\backup_full_par t_2_of_3_20081004-151501.92X.bin part 3 of 3... Reading... file saved: C:\mobilestuff\InfinityBox\VModule\backup_full_par t_3_of_3_20081004-151825.92X.bin error: unknown flash chip: 048A:EA00:3FFD:EA00 error: unknown flash chip: 048A:EA00:3FFD:EA00 error: unknown flash chip: B510:48EF:2280:5014 error: unknown flash chip: 048A:EA00:3FFD:EA00 error: unknown flash chip: 6646:2373:FFFF:FFFF error: unknown flash chip: 048A:EA00:3FFD:EA00 Finished, time used: 924 sec [ |
10-05-2008, 18:22 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You need to use HModule.exe for this phone due to VModule is quite old, all updates for this kind of models will be released in HModule. |
10-06-2008, 03:08 | #3 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | ok, I succeded, but for others to know, it didnot work with hmodule version x.23, I tried with it and it said Everything OK, but ohone was still locked, I had to upgrade to x.26 then update dongle firmware also for this latest version to work, it unlocked Ok. By the way there was not way for me to know that HModule makes some models also made by VModule, this is something that should be documented... |
Ut Starcom Gprs 779 Unlocked By Vygis Vpower | denisirias | VygisToolbox | 3 | 01-29-2009 11:56 |
please help problem unlock utstarcom model gprs 779 | treo29 | Infinity-Box | 2 | 08-24-2007 02:25 |
Please help to unlock myX5-2 GPRS | NICOTEL | SMTi | 3 | 06-28-2007 02:37 |
How to unlock Timeport T260 GPRS | Lazso | Motorola P2k | 0 | 09-20-2001 10:47 |
