Fatal error, buffer empty! Phone connection lost??? Operation : Read Flash [ v1.49 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 71 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 71 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7001005631303031365014E03F7EB2C9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 61001 [eMMC] : FLASH_CID : 7001005631303031365014E03F7EB2C9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000386000000 [eMMC] : FLASH_UCP : 14432 MiB [eMMC 16 GiB] DEV RID : 0xC1E9FF55CCCF677E176C8AB17D79F1B0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : INFINIX ProdName : Infinix HOT 3 ProdModel : Infinix HOT 3 Device : W90918A2 Infinix HOT 3 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2.19_WT6580.WE.XIAN.L_P16 [Read Ok] : preloader_t90918a2.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img Fatal error, buffer empty! Phone connection lost??? Error while reading block! Something went wrong :( Read error :( Operation Failed Elapsed: 00:09:18 Reconnect Power/Cable! win 10 64pit |
Operation : Read Flash [ v1.49 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 71 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 71 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7001005631303031365014E03F7EB2C9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 61001 [eMMC] : FLASH_CID : 7001005631303031365014E03F7EB2C9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000386000000 [eMMC] : FLASH_UCP : 14432 MiB [eMMC 16 GiB] DEV RID : 0xC1E9FF55CCCF677E176C8AB17D79F1B0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Fatal error, buffer empty! Phone connection lost??? Read error :( Operation Failed Elapsed: 00:08:20 Reconnect Power/Cable! |
"Connection lost" Check your cables first, then Read again |
Almirakl ergonomics uniforms Jasmine works in withdrawing 10.10 |
