04-17-2018, 20:32 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: egypt Age: 37
Member: 419703 Status: Offline Thanks Meter: 123 | Cm2mtk v2 new updates haer |
04-19-2018, 19:17 | #2 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | Chinese Miracle-2 MTK/Mediatek v2.00 - new CPU support, new features, new options MTK 6570 CPU support: with NAND memory with eMMC memory Read Info - Complete device info, Security info Read Firmware - Factory Scatter format [ NAND supported - WorldFirst and unique! ] Write Firmware - Factory Scatter Format [ NAND supported - WorldFirst and unique! ] Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6750 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6755 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6757 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6763 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6797 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool --- Under Test --- MTK 6758 CPU support: Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool MTK 6739 CPU support: with NAND memory with eMMC memory Read Info - Complete device info, Security info Read Firmware Write Firmware Read NVRAM Write NVRAM Repair Security Formay FS - FRP, Settings, Privacy ( and mixed/special mode ) MemoryTool Main - New look and design. All simplified and optimized much, as possible. [ please refer to v2 interface introduction ] - New core. All code made from scratch. - New boot chain selection mode - automatic ( via defined user combination ) or manual. - New connection - Complete error handling and explanation - Internal EMIDB cover 99% of existing memory devices on both - NAND and eMMC devices - Easy end user customization for adding support for new device etc. Flasher - Completely new flasher design, which allow customize whole flashing process [ please refer to v2 interface introduction ] FW Reader - Completely new core, which allow handle all existing types and flash devices. Service - Security repair NOT require reboot to meta, not required CDC drivers or whatever else. All direct. - Format FS include different mode, optimized for different secure devices type ( with FORMAT, WRITE protection ) - During NVRAM read/write SW also verify it condition and data MEMORY TOOL activated! Easy, fast and ultimate solution now come in MTK too! - Support eMMC and NAND flash IC secure - Allow READ, WRITE, ERASE partitions - Show partitions states and info only for eMMC devices - Allow RE-init PMT ( from scatter ) Other Lot of other changes from v1 line, which not mandatory to mention Known issues/warnings/info: 1. [NAND on MT6570] v1712, v1736 loader packages NOT SHOULD BE USED! Since they have ftl/ecc errors! In result you will give read/write FW errors and rest problems at all. Recommend use v1724 for FACTORY FW flashing, v18xx line for Infinity FW Flash Read and Write 2. [NAND on MT6570] In some cases "stuck on logo" devices can be fixed only via FFU (whole flash) format! 1. [NAND on MT6570] UBI SPARSE image flashing may take MUCH time (up to 5 minutes and more) for some devices! 3. [MEMORY TOOL] Partitions state on MEMORY TOOL will be empty in MT6570 NAND phones, it is normal and cannot be fixed. Read-write data, which you want, ignore "EMPTY" states. 4. [MEMORY TOOL] Old protocol secure devices (MT6750/MT6755) - LeEco and similar In some cases WIPE partition may not work! 5. ADL checksum MAY NOT WORK CORRECT on MT6570 NAND/eMMC devices! Result - stuck after system/userdata partition flashing 6. FileSyhstems flashing on some SBC-enabled devices ( except SYSTEM/CACHE/USER ) may fail! Solution - exclude them from flashing list. 7. Device with NV_TYPE2 security may not work yet for repair sec! |
The Following User Says Thank You to GSM_BB5 For This Useful Post: |
