Old 04-28-2016, 06:35   #1 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Lg E445 Imei Repair ?
Posiible lg e445 imei repair ?
Try with Cm 2 But Error
Operation : Repair Security [ v1.47 ]
Wait for phone...
Phone found! [ 124 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A3B14C313B
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 908EBB1CDA5AF46431A04A2545DAFF65
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Error on Security Repair , Code : 0x6
Make sure about mobile is working and alive!
Check BaseBand state also, fix if need!
Operation Failed
Elapsed: 00:00:09
Reconnect Power/Cable!
Old 04-28-2016, 08:45   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Use LATEST CM2MTK module version.
Select LG E-series.
Do repair.
Old 08-11-2016, 16:19   #3 (permalink)
dey mobiles's Avatar
Member: 799558
Thanks Meter: 430
Thanks JayDi bro
IMEI Rpair Done LG E445
Operation : Repair Security [ v1.54 ]
Wait for phone...
Phone found! [ 86 ]
Sync...
Device boot not done
Check Drivers
Try again
Init Service mode failed, something went wrong :(
Wait for phone...
Phone found! [ 86 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use SecMode DA
DAgent sent , init HW now
[eMMC] : FLASH_CID : 90014A4834473164048601A36C464125
DEV RID    : 0xE8130045CA9A8B3A23C8D894F9588854
EXT RAM    : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
IMEI [0] : 353380xxxxxxxxx
IMEI [1] : 353380xxxxxxxxx
Set IMEI [0] : 353380xxxxxxxxx
Set IMEI [1] : 353380xxxxxxxxx
Repair done!
Done!
Elapsed: 00:00:18
The Following User Says Thank You to dey mobiles For This Useful Post:
Page generated in 0.14843 seconds with 8 queries
