05-01-2021, 16:18 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: colombia Age: 41
Member: 254733 Status: Offline Thanks Meter: 28 | Firmware SKYCELL A2 Joker? Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 41 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : sp7731g_1h10_hd_oversea Model Brand : SKYCELL Model Device: sp7731g_1h10 AndrVersion : 9.0 BaseBand CPU: SP7731GEA_HDR CompileDate : 1/07/2020 12:04:51 p.*m. Project Ver : SKYCELL_A2_Joker--20200701 Model Ext : A2 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:49 Reconnect Power/Cable! |
The Following 13 Users Say Thank You to gsmpigmento For This Useful Post: |
07-14-2021, 20:31 | #3 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Colombia Age: 42
Member: 452143 Status: Offline Thanks Meter: 197 | Quote:
Good day friend, you could find that firmware, I have a phone of those in logo. Salu2 | |
The Following User Says Thank You to karurosu316 For This Useful Post: |
09-02-2021, 23:46 | #4 (permalink) |
Junior Member Join Date: Jun 2008
Member: 790759 Status: Offline Thanks Meter: 5 | good greetings colleagues I am trying to pass the firmware of skycell a2 spd7731g I took it from a new one but it gave me an error when going for the system part and then it no longer allows me to try again it asks for fdl |
The Following User Says Thank You to MORFEO54 For This Useful Post: |
09-03-2021, 23:35 | #6 (permalink) |
Member: 790759 Status: Offline Thanks Meter: 5 | BootVersion : SPRD3 Boot : INF : SKYCELL : A2 Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... >>> ERROR : FLASH FDL NOT started! >>> Error : Fail to boot FDL! >>> Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! this problem sir |
09-04-2021, 10:05 | #7 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Change it and post result | |
09-04-2021, 21:34 | #8 (permalink) | |
Member: 790759 Status: Offline Thanks Meter: 5 | Quote:
BootVersion : SPRD3 Boot : INF : SKYCELL : A2 Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : UserData Wipe Ok : Cache Reconnect Power/Cable! Done! Elapsed: 00:00:44 I explain the situation for frp and factory restore, it allows me by selecting skycell model a2 but any phone that I try to update the software only allows to load up to a certain part of the dev system and then it no longer recognizes that computer, whatever it does, it leaves them dead | |
09-04-2021, 21:48 | #9 (permalink) | |
Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Load PMT PMTMng : 0x20 PMTMng : Update failed! ERROR : 00000084:84000000FF7B7E00 SYS : OPERATION FAILED! this is the log of the precise error thank you | |
09-05-2021, 11:52 | #10 (permalink) | |
09-07-2021, 20:28 | #11 (permalink) |
Member: 790759 Status: Offline Thanks Meter: 5 | Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 hello sir It is the latest version, could you provide me with the fdl of the skycell a2 to see if loading them I can perform the flashing I have several computers and 3 dead when trying to revive with infinity thank |
