11-11-2015, 13:33 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1763380 Status: Offline Thanks Meter: 86 | first use cm2 how to remove virus model evercoss a28s Operation : Check / Read Info [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 002C00BC009000660054000000000000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0088 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT [NAND] : FLASH_DIE : 002C 00BC 0090 0066 0054 0000 0000 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
11-11-2015, 14:09 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | 1 MTK nand chip not support for remove virus at this time u need flash it with good firmware 2 for MTK emmc use these step take backup ( if u dont have perfect flash file its recommended ) use SA in extra tab after that in service tab use fectory reset all done |
The Following User Says Thank You to sneha For This Useful Post: |
