05-22-2007, 18:40 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Age: 43
Member: 92203 Status: Offline Thanks Meter: 0 | Flash Benq Ef51 French No Working Device: BenQ EF51 Checking data, wait... Action: Flash write "smart write" active Write: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 203125 Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 001C:00C8001C00C8 flash: Mitsubishi B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 001C:00C8001C00C8 startup mode adjusted flash: Mitsubishi B 8Mb Err: answer#00 try#1 to recover erase error#00 Err: answer#00 try#2 to recover erase error#00 Err: answer#00 try#1 to recover write error at 00002000 Err: answer#00 try#2 to recover write error at 00002000 Err: answer#00 try#3 to recover write error at 00002000 Err: answer#00 try#4 to recover write error at 00002000 Err: answer#00 try#5 to recover write error at 00002000 Err: answer#00 try#6 to recover write error at 00002000 Writing Fail Finished, time used: 84 sec Remove/Install battery now ! HELP ME URGENT THANKS |
05-30-2007, 15:39 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In the dark side ;) Age: 44
Member: 21508 Status: Offline Thanks Meter: 186 | i didn't succeeded with any EF51 (unlock, flash.. ) .. please remove this soft from the list as it's not working! COM3 selected Device: BenQ EF51 Checking data, wait... Action: Flash write "smart write" active Skip: Firmware Skip: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 001C:00C8001C00C8 flash: Mitsubishi B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Language Pack Flash: 001C:00C8001C00C8 flash: Mitsubishi B 8Mb Err: error flash vpp Err: answer#00 try#1 to recover write error at 01230000 Err: error checksum try#2 to recover write error at 01230000 Err: error try#3 to recover write error at 01230000 Err: answer#00 try#4 to recover write error at 01230000 Err: answer#00 try#5 to recover write error at 01230000 Err: answer#00 try#6 to recover write error at 01230000 Err: answer#00 try#1 to recover write error at 01232000 Err: answer#00 try#2 to recover write error at 01232000 Err: answer#00 try#3 to recover write error at 01232000 Err: answer#00 try#4 to recover write error at 01232000 Err: answer#00 try#5 to recover write error at 01232000 Err: answer#00 try#6 to recover write error at 01232000 Err: answer#00 try#1 to recover write error at 01234000 Err: answer#00 try#2 to recover write error at 01234000 Err: answer#00 try#3 to recover write error at 01234000 Err: answer#00 try#4 to recover write error at 01234000 Err: answer#00 try#5 to recover write error at 01234000 Err: answer#00 try#6 to recover write error at 01234000 Err: answer#00 try#1 to recover write error at 01236000 Err: answer#00 try#2 to recover write error at 01236000 Err: answer#00 try#3 to recover write error at 01236000 Err: answer#00 try#4 to recover write error at 01236000 Err: answer#00 try#5 to recover write error at 01236000 Err: answer#00 try#6 to recover write error at 01236000 Err: answer#00 try#1 to recover write error at 01238000 Err: answer#00 try#2 to recover write error at 01238000 Err: answer#00 try#3 to recover write error at 01238000 Err: answer#00 try#4 to recover write error at 01238000 Err: answer#00 try#5 to recover write error at 01238000 Err: answer#00 try#6 to recover write error at 01238000 Err: answer#00 try#1 to recover write error at 0123A000 Err: answer#00 try#2 to recover write error at 0123A000 Err: answer#00 try#3 to recover write error at 0123A000 Err: answer#00 try#4 to recover write error at 0123A000 Err: answer#00 try#5 to recover write error at 0123A000 Err: answer#00 try#6 to recover write error at 0123A000 Err: answer#00 try#1 to recover write error at 0123C000 Err: answer#00 try#2 to recover write error at 0123C000 Err: answer#00 try#3 to recover write error at 0123C000 Err: answer#00 try#4 to recover write error at 0123C000 Err: answer#00 try#5 to recover write error at 0123C000 Err: answer#00 try#6 to recover write error at 0123C000 Err: answer#00 try#1 to recover write error at 0123E000 Err: answer#00 try#2 to recover write error at 0123E000 Err: answer#00 try#3 to recover write error at 0123E000 Err: answer#00 try#4 to recover write error at 0123E000 Err: answer#00 try#5 to recover write error at 0123E000 Err: answer#00 try#6 to recover write error at 0123E000 Writing Fail Finished, time used: 403 sec Remove/Install battery now ! |
For test: BenQ EF51, EF71, CL71 | InfinitySupport | Infinity-Box | 34 | 01-18-2012 11:43 |
Error when flash Benq-siemens EF51 | suntluk | Infinity-Box | 4 | 07-04-2009 10:11 |
Battery BenQ EF51 NEEDED | Daeron | Wanted Products | 0 | 02-26-2008 18:47 |
how to flash benqsiemens ef51 | repairunlock | Infinity-Box | 2 | 05-24-2007 20:53 |
Benq EF51 unsuported....... | frenchi | Infinity-Box | 6 | 04-13-2007 18:10 |
