Old 04-26-2009, 08:37   #1 (permalink)
Member: 383211
Thanks Meter: 131
flash file need PROWAVE25_07A_PCB01_GPRS_MT6225_S00.M222_R1_0_23_1 4.BIN
i need this flash file "PROWAVE25_07A_PCB01_GPRS_MT6225_S00.M222_R1_0_23_ 14.BIN"
this mobile is on pen calibration.i check it on pen calibration mode1 to mode 4.but mobile is still on pen calibration.i formate it but no luck .now i want to flash it.plz help me.below is the formating log
OM5 [VCP2] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:C003:0004
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: PROWAVE25_07A_PCB01_GPRS_MT6225_S00.M222_R1_0_23_1 4.BIN
ver. sw2: M222_R1.0.23.14, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
Finished, time used: 56 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 04-26-2009, 17:41   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
cant you calibrate touchscreen manualy? by taping LCD with pen?
calibration is needed only when touchscreen function is broken
Old 04-27-2009, 14:13   #3 (permalink)
Member: 383211
Thanks Meter: 131
the tech screen is broken and not work in manually.
Old 04-27-2009, 14:14   #4 (permalink)
Member: 383211
Thanks Meter: 131
the tech screen is broken and not work manually.i tried every possible things
Old 04-27-2009, 14:17   #5 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 280
it can be replaced if u wish?
Old 05-04-2009, 12:06   #6 (permalink)
Member: 383211
Thanks Meter: 131
plz tell me in detail how can be it replaced.
Old 05-04-2009, 13:22   #7 (permalink)
Member: 190344
Thanks Meter: 280
use sugical blade to remove the sticking tape from the lcd.
the strip always contains 4 connections.that are X1, X2, Y1, Y2
read this thread
http://forum.gsmhosting.com/vbb/show...06&postcount=1
and
http://forum.gsmhosting.com/vbb/show...11&postcount=2
http://forum.gsmhosting.com/vbb/show...18&postcount=3
http://forum.gsmhosting.com/vbb/show...31&postcount=5
br
hamid
The Following User Says Thank You to biochemistali For This Useful Post:
MIKI23_07A_PCB01_GPRS_MT6223P_S00.VGNY238_LD_ZI_01 .BIN flash file needed.please help GOODNESS Chinese Models & Cloned Phones 0 06-08-2009 20:30
DRV R52 Flash file need? MTK_ROMINFO_v04 e550_j7turk_e550_gprs_mt6226_s01.01_1.bin hacker_gsm Chinese Models & Cloned Phones 0 09-04-2008 09:08
*.bin flash file needed WAZE x1x to x45/x50 2 03-22-2003 20:57
partial flash file for 3210 v.4.02 needed sdimitri Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-17-2001 17:27
T28 Bin + Flash files needed Gfunk Old Ericsson Phones & Sony Phones 0 05-20-2001 15:58
Page generated in 0.20079 seconds with 9 queries
