flash write error riends...whichever model either chinese or fly or anyone whose rx tx detected by any box,,,read eprom done ...then flash write error in infinty box.....e.g. fly v6o sp unlock time shows this..checked in 4 pc,3 infinity........plz help |
Good day ! If you really have any problems pls post here operation log so we can check what is the problem |
help me brorher n95 rm 17 |
Sometimes it's good idea to read text that you can see in software log window ! Set baud... 921600 error: wrong answer: C5 error: can't work at this speed, use lower speed So just use 115200 baud ! |
n95 rm17 |
What cable you have used ? Is it was cable connected to Infinity-Box or other cable ? |
COM7 [VCP0] selected Device: Fly-V60 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 chip: 0011:4E93:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SIMC23_07A_PCB01_GPRS_MT6223_S00.NF_S1V01_02B12_SI MLOCK.BIN ver. sw2: NF_S1v01.02b12_simlock, 00000000 ffs offset/size: 00700000/00100000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[SIMC23_07A_PCB01_GPRS_MT6223_S00.NF_S1V01_02B12_SI MLOCK.BIN]]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[SIMC23_07A_PCB01_GPRS_MT6223_S00.NF_S1V01_02B12_SI MLOCK.BIN]_20080621-123018.B0E.bin flash: 01227E22022201:2AEA0000000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... ................. flash: 01227E22022201:2AEA0000000000 flash: 01227E22022201:2AEA0000000000 Write: area 0/1 error: error# 000000FF error: flash write error: 00460000:00002000 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC1A2E3B3B3BF32E3B3B3B022E3B3B3B452E3B3B3B FC2E3B3B3BFC2E3B3B3B3A2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BBD2E3B3B3B1D2E3B3B3BD02E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3B FC2E3B3B3B error: can't write required area error: additional parameters detection failed Special operation Done Write... error: no any expected answer error: no any expected answer: wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer: wrong answer after chip cfi request error: no any expected answer error: no any expected answer: wrong answer after chip id request Write Fail Finished, time used: 159 sec Remove/Install battery now ! |
@zandoo try to repeat unlock process several times. What was original phone state ? |
COM5 [VCP1] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:3A41:D408 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.F5FB7B78.[KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN_8FB1E937].rpl ==================== New firmware detected: KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: F5FB7B78 identification#1 protocol ver: 04 ver. sw1: KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN ver. sw2: MAUI.06B.W07.04.MP.V32, C8164E70 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2CEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN]_20080621-215918.B0E.bin flash: EC257E25082501:2CEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_F5FB7B 78_KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07 _04_MP_V32.BIN_8FB1E937_20080621-220216.B0X.bin Area: Firmware flash: EC257E25082501:2CEA0000000000 Write: Firmware error: error# 000000FF error: flash write error: 00000000:00002000 error: wrong answer: B0 error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 error: no any expected answer error: flash write error: 00000000:00002000 detect device identification#2... detection phase #1... error: unexpected termination/freez: 00000000 warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_F5FB7B 78_KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07 _04_MP_V32.BIN_8FB1E937_20080621-220448.B0X.bin Finished, time used: 755 sec Remove/Install battery now ! help help |
@imamchoo try to repeat unlock process several times. What was original phone state ? |
