John(LMT) | 05-13-2015 20:36 | Flashing backup made by CMK2MTK I made a Read Full Flash operation, and now i need urgently to put it back to the phone but it is showing the next error, i hope you could help me. Code:
Chinese Miracle II [MTK module] v 1.20
Load File
FileVersion : MT6592
Load File Ok
Operation : Flash [ v1.20 ]
======= Flash
Files set for flashing :
[ MCU ] : MT6592__ALPS__706v92_jbla_fhd__e2706v92_jbla_fhd__ALPS.KK1.MP1.V2.11__Android_4.4.2__20141103_081700.ispff
Wait for phone...
Phone found! [ 100 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6592
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6592_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 1501004B3758564D420187EBDEECC15F
DA Stat : v4.2 on BBID : 0x8A
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BMVX7
[eMMC] : FLASH_CID : 1501004B3758564D420187EBDEECC15F
[eMMC] : FLASH_LEN : 0x00000001D2000000
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ISPFF ID : 6592 , TARGET ID : 6592
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase failed :(
Write Flash now ...
Init Ok , Sending blocks ...
Write failed :(
Flash Error!
Check Cable, Battery , try again
Operation Failed
Elapsed: 00:00:34
Reconnect Power/Cable! |
