05-22-2008, 06:13 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 775560 Status: Offline Thanks Meter: 58 | flashing dead motorola c168 with infinity ! Device: Motorola C168 "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 flash: ST M58WR064FT, M36D0R6040T0 T 8Mb version sw: !0000 version sw: ! Check flash Done Check parameters... reading Motorola C168_eeprom_calibration-1... file saved: backup_Motorola C168_eeprom_calibration-1_20080520-132638.69E.bin Check parameters Done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection declined by user Check data Fail Finished, time used: 17 sec Remove/Install battery now ! what wrong about that ? cause i already use with the right file flash like in infinity file flash decription fo c168 ! |
05-22-2008, 06:32 | #2 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 343326 Status: Offline Thanks Meter: 1,463 | Dear , First of all check u r model selection Check u r battry...... If not full charged..... Chrge the battry full Also check with another method like 2 or 3 Post result. |
05-22-2008, 06:49 | #3 (permalink) |
Member: 775560 Status: Offline Thanks Meter: 58 | COM3 [VCP5] selected Device: Motorola C168 "advanced chip detection" active Action: flash write "smart write" active "format ffs" active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 flash: ST M58WR064FT, M36D0R6040T0 T 8Mb version sw: !0000 version sw: ! Check flash Done Check parameters... reading Motorola C168_eeprom_calibration-1... file saved: backup_Motorola C168_eeprom_calibration-1_20080520-132936.69E.bin Check parameters Done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data Done Writing... Area: Firmware flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Firmware Area: Flex flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Flex Area: Language Pack flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Language Pack Area: Images flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Images Area: Melody flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Write: Melody flash: 208810FFFFFFFF:20881000000000 flash: 208810FFFFFFFF:20881000000000 Erase: ffs ffs format complete Writing Done Finished, time used: 258 sec Remove/Install battery now ! this log when i try to continue flashing even the warning still show up , result the phone still dead ! |
05-22-2008, 06:53 | #4 (permalink) | |
Member: 775560 Status: Offline Thanks Meter: 58 | Quote:
i already do that , but the problem still exist , dead phone ! next trick please ! by the way thanks for your guide for me ! | |
05-25-2008, 14:27 | #7 (permalink) |
Member: 775560 Status: Offline Thanks Meter: 58 | the phone alraedy dead when it come to me , the owner said that the phone dead after recieve a call ! , so what should i do infinity suport ? than if i try resolve the dead phone that log in my earlier post is the result ! |
05-25-2008, 15:53 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | If you see the same message (wrong model) after several (main+lp+flex+images+melod) flash tries this means that phone flash chip is damaged and can not be written correctly. you must open phone and check it's hardware. |
05-26-2008, 10:45 | #10 (permalink) | |
ok thanks for your help , i try first ! | |
Help me to unlock motorola w375 with infinity-box???? | svchost | Infinity-Box | 8 | 03-29-2019 19:48 |
succsessfully unlock motorola w370 with infinity box | Harkishan singh | Infinity-Box | 5 | 08-11-2010 19:44 |
flashing dead motorola c168 whit infinity ! | juwanapati | Infinity-Box | 8 | 09-15-2009 00:03 |
succsessfully unlocked motorola w377 with infinity box | Harkishan singh | Infinity-Box | 5 | 11-11-2008 08:12 |
motorola C168 with multibox | brahim12 | Multi-Box | 0 | 02-15-2008 15:38 |
