09-29-2010, 02:00 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: Intan HP
Member: 1002567 Status: Offline Sonork: abc Thanks Meter: 33 | Flashing K220 always error COM8 [VCP0] selected module v1.38 Device: Sony-Ericsson-K220i "advanced chip detection" active Action: flash write "smart write" active write: Firmware K200i_K220i_main_R1AA008_CXC1250816_En_Cn_Vn_Indon esia_Malaysia_Filipino.80M.bin write: Flex/Customization K220i_flex_R1AA008_CXC1250816_CDA102806-1_R4A.80F.bin skip: Language Pack write: FFS/File system K220i_ffs_repair_default.80E.bin skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 01227E22212200:92EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb software version: R1AD001 software version: CXC1250816 version flex: CDA102806/1 imei: 35619701067683 Check hardware done Read data ... Read data done Check data ... Check data done Write ... Area: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware error: error# 0000FFFF error: flash write error: 00002000:00002000 error: error# 0000FFFF error: flash write error: 00002000:00002000 error: error# 0000FFFF error: flash write error: 00002000:00002000 Write fail error: operation failed Finished, time used: 39 sec Remove/Install battery now ! |
09-29-2010, 05:50 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Côte d'Ivoire_Ghana_Nigeria Age: 40
Member: 846968 Status: Offline Sonork: 100.1613167 Thanks Meter: 139 | Area: Firmware flash: 01227E22212200:92EA0000000000 Write: Firmware error: error# 0000FFFF error: flash write error: 00002000:00002000 error: error# 0000FFFF error: flash write error: 00002000:00002000 error: error# 0000FFFF error: flash write error: 00002000:00002000 Write fail error: operation failed Finished, time used: 39 sec Remove/Install battery now are you sure that you don't release your hand on mobile when boot will pass????? try against and still your hand on power ""Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200"" don't put you hand try it ok |
09-29-2010, 06:05 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: lake city
Member: 386868 Status: Offline Thanks Meter: 125 | also try to clean the board before flashing it , coz due to water logging the set is not ready to perform the write operartion, specially do thoroughly clean the area near the data connector........... wbr: sanjubhai. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
