flashing N95 2sim problem help me please what is this problem? :confused: COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:D2CC:183A high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 04227E22212200:29EA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:29EA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 04227E22212200:29EA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 04227E22212200:29EA0000000000 flash: Fujitsu AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B124F3A6.[T6226_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP _V3_F3_1.BIN_AF849230].rpl identification#1 detection finished device-id: B124F3A6 identification#1 protocol ver: 04 ver. sw1: T6226_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP _V3_F3_1.BIN ver. sw2: MAUI.05C.W06.16.MP.V3.F3.1, CF6D7B50 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 04227E22212200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP _V3_F3_1.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.MAUI_05C_W06_16_MP _V3_F3_1.BIN]_20081126-055534.B0E.bin flash: 04227E22212200:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B124F3A6_T6226_05C_PCB01_GPRS_MT6226_S01 .MAUI_05C_W06_16_MP_V3_F3_1.BIN_AF849230_20081126-055542.B0X.bin Area: Firmware flash: 04227E22212200:29EA0000000000 Write: Firmware Area: Eeprom/ffs flash: 04227E22212200:29EA0000000000 Write: Eeprom/ffs error: error# 0000006C error: flash write error: 00EB0000:00002000 error: error# 0000006C error: flash write error: 00EB0000:00002000 error: error# 0000006C error: flash write error: 00EB0000:00002000 error: error# 0000006C error: flash write error: 00EB0000:00002000 error: error# 0000006C error: flash write error: 00EB0000:00002000 error: error# 0000006C error: flash write error: 00EB0000:00002000 error: error# 0000006C error: flash write error: 00EB0000:00002000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_B124F3A6_T6226_05C_PCB01_GPRS_MT6226_S01 .MAUI_05C_W06_16_MP_V3_F3_1.BIN_AF849230_20081126-062313.B0X.bin Finished, time used: 2006 sec Remove/Install battery now ! all is ok cable and pinouts :confused::confused::confused: |
hello! what cable do you use? looks like flash internal fault or bad soldering |
we use pin finder with the correct cable 12 pin I thing that the problem is in the eeprom module |
we use pin finder with the correct cable 12 pin I thing that the problem is in the eeprom module help please |
hello! resolder or heat flash IC |
