12-11-2007, 16:12 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: world wide
Member: 57836 Status: Offline Thanks Meter: 47 | Fly SL399E NP code (sim lock) i knew this model is not supported yet, ok, i have the phone in my hand now and i had agree with the *******r to keep it at me for few days. the phone came with usb cable and virgin mobile sim card, when i connect it to pc, it act the same like chines nokia N95 (accepts driver for chines nokia N95 & open disc explorer). now, what do i need to help you infinity ppl to add this model ? |
The Following User Says Thank You to fethi For This Useful Post: |
12-13-2007, 11:17 | #3 (permalink) |
Member: 57836 Status: Offline Thanks Meter: 47 | ok the phone got connector with 18 pin ( it's usb cable seems like LG U310 ) keypad up 1..........................18 3= gnd 5= gnd 6= gnd now how can i find the tx and rx pin thank you |
12-13-2007, 11:50 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | keyboard top 1.........18 3: Gnd 12: Tx 13: Rx Try this pinout, if not work just swap Rx <-> Tx Please, use "ChineseMiracle" software and read flash before unlock try. After you have made backup you can try to make "read codes" or "smart fast" unlock method. please, send "backup_flash..." files to [email protected] also pls send "backup_system_log..." files (if exist), it's important. Waiting for your results. |
12-13-2007, 16:54 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Other ways: 1. be sure that you have tried to swap Rx and Tx pins 2. open phone and check that phone connector not damaged 3. check where is +Charge pin and +batetry pins on phone connector 4. What is full text from phone back label ? |
12-13-2007, 21:18 | #7 (permalink) | |
Member: 57836 Status: Offline Thanks Meter: 47 | Quote:
1. i've tried to swap rx and tx pins 2. phone connector not damaged (first open by me ) 3. sorry for that cause i don't have it's charger ( only usb cable for pc ) 4. full text from phone back label is: Fly fccid: RV2ZMEM1075B Type: 07-110673 Model: SL399E S/N: 070820 S_H_6226M Imei no: 35xxxxxxxxxxxx made in korea also i attache here pics for the phone back label and the main board thank you | |
12-13-2007, 21:24 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Could you, please, tell me what connector pins was used for USB D+/D- and for USB +V ? Also if you can find where is +battery pin on connectoor it will be very good. After we will see this info we can think what is Rx/Tx pins. |
12-15-2007, 15:00 | #10 (permalink) |
Member: 57836 Status: Offline Thanks Meter: 47 | InfinitySupport it is hard to me find connector pins used for USB D+/D- and for USB +V cause they are very complicated and every pin gives deffrente foltage value (i am not smart in this but i want to help), but let me tell you i got the charger and i find out the pins 17 - 15- 14 are V+ and i made this file to help you http://rapidshare.com/files/76740562/1.jpg.html i hope you find those files helpful thx |
12-15-2007, 18:05 | #14 (permalink) |
Member: 57836 Status: Offline Thanks Meter: 47 | i hope this picture that i make can help you so i think : pin 3 USB Data + = pin 8 in charger pin 2 USB Data - = pin 9 in charger pin 4 USB = pin 14-15-16 in charger pin 1 USB = pin 4-5 in charger i got this result by touching pins with multimeter and check the picture thank you |
12-15-2007, 20:35 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i am little confused... this picture do not match with your previouse post. before you told 3,5,6 is GND, on picture is 4,5. before was charge pins 14,15,17 now is 14,15,16 can you check this once again. |
plz help me unlock my fly slt100 ,phone says enter np code | ARAB GSM | Infinity-Box | 8 | 09-15-2010 01:03 |
Fly sl390e np code | Samuel maduka | Infinity-Box | 1 | 01-16-2010 20:50 |
fly sl399e enter code prob.... | EJAZGUL | Infinity-Box | 18 | 11-08-2009 02:37 |
fly sl399E unsuccessfull unlock wrong code help | danex_2000 | Infinity-Box | 2 | 07-11-2008 16:52 |
FLY SL500i np code | phoneteam | Various | 2 | 01-21-2008 06:30 |
