FLY SL500i I read code but after write code phone ask to another how unlock it ?? COM8 [VCP9] selected Action: read codes unlock method: read codes Model: Fly SL500i Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6219:8B02:8B01]... CPU: MT6219 chip: 0031:9927:E0EA CPU: MT6226MA detected Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: SL900A.05C.W06.08.MP.V72 Version: ESL6227_05C_HW 60 byte(s) read imei: 35524701032573 connection Ok 208 byte(s) read Phone lock: Off Network lock: On Network subset lock: Off Service provider lock: On Corporate lock: Off IMSI lock: Off Auto lock: Off NP code: 84014464/48104446 locked to: FFF-FF SP code: 0000000000003344/0000000000003344 CP code: FFFFFFFFFFFF0000/FFFFFFFFFFFF0000 IMSI code: 0190360092780000/1009630029870000 Phone code: 0000000000000000 Finished, time used: 277 sec Remove/Install battery now ! After write SP code I give ok now ask about MASTER CODE what now ENTER ?? ?? ?? |
Hello, What MModule version you have used ? Do you have original eeprom backup ? |
i think you Sp Area is not good so you have to flash your phone then unlock it Br Faisal_Computer |
Hello, Select "standard" unlock method and make "unlock" again. Post log here in case of problems. |
thank you infinity team succussful unlock fly sl 500i COM12 [VCP1] selected Device: Fly SL500i Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6219:8B02:8B01]... MT6226MA detected boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Identification... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [standard] (or higher) generation protocol ver: 04 ver. sw1: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN ver. sw2: SL900A.05C.W06.08.MP.V72.F2 ffs offset/size: 00E00000/00200000 warning: invalid identification, ask/rpl calculation reqired error: rpl file not found: C:\Program Files\InfinityBox\MModule\id.._SL900A_UKFLY_PCB01_ GPRS_MT6226M_S01.SL900A_05C_W06_08_MP_V72_F2.BIN_F FFFFFFF_.rpl warning: unknown identification structure: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN_FFFFFFFF error: ASK file can't be created, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update reading [eeprom[SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN]]... file saved: backup_eeprom[SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN]_20080823-082256.B0E.bin flash: 89881500010001:89881500000000 Identification Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... ................................. flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: area 0/1 ............................... Finalization Done Write... flash: 89881500010001:89881500000000 Write: eeprom Write Done Finished, time used: 407 sec Remove/Install battery now ! |
We are really glad to hear about good results. |
Unlocking Fly SL500i by IMEI I need code for Fly SL500i, IMEI: 352745020151639, HI network (KPN Netherlands/Holland). Many thanks |
You must make your posts in correct forum section. Here is Infinity-Box support forum but not free unlock codes request section ! |
Thanks for info and direction. |
I have a mobile Fly SL 500i. I need to unlock it . who can help me please??? It asks for a MASTER CODE... |
Just run Infinity-Box software and unlock phone. |
Need fly500i flash file Quote:
please send me flash file model SL500i 071019 s_H(c)_6226M_o_s |
Please, download SL500i flash files from support area. |
