fly sl600 master code unlock done :)log is here COM3 [VCP0] selected Device: Fly-SL600-Vodafone Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "sp-unlock" unlock method: standard Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6227:8A02:8A01]... CPU: MT6227 chip: 0031:EF1E:E6A4 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SL300_UKVODA_PCB01_GPRS_MT6227_S01.SL300_05C_W06_0 8_MP_V87_F1.BIN ver. sw2: SL300.05C.W06.08.MP.V87.F1, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[SL300_UKVODA_PCB01_GPRS_MT6227_S01.SL300_05C_W06_0 8_MP_V87_F1.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL300_UKVODA_PCB01_GPRS_MT6227_S01.SL300_05C_W06_0 8_MP_V87_F1.BIN]_20090311-102901.B0E.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data... detection procedure, wait... detection procedure completed Patch required data Done Special operation... detecting additional parameters... .................................... flash: B0001D00000000:B0001D00000000 flash: B0001D00000000:B0001D00000000 Write: area 0/1 ............................ additional parameters detected Ok Special operation Done Write... flash: B0001D00000000:B0001D00000000 Write: eeprom Write Done Finalization... Finalization Done Finished, time used: 476 sec Remove/Install battery now ! thanx infinity team |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
