05-09-2008, 15:24 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 44
Member: 93610 Status: Offline Thanks Meter: 45 | Fly Slt100 Flashing Error i have to tried to unlock a fly slt 100 mobile phone and it unlocked & asked a master code, after searching on the forum they ask to flash the phone, so i try to flash and it give only error, the error is COM8 [VCP0] selected Device: Fly SLT100 Checking data, wait... Action: write NAND flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw1: SLT100_HMERID_PCB04_GPRS_MT6228_S02.MAUI_06A_W06_3 6_MP_V36.BIN ver. sw2: MAUI.06A.W06.36.MP.V36, 00000000 ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 loader: 3.1.02 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] NOR chip is not installed Initialize Fail Finished, time used: 56 sec Remove/Install battery now ! so please try to help me. THANK YOU |
06-12-2013, 11:40 | #7 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | Quote:
..flash stop at 3% 10 or 26 %...battery full 29 [VCP0] selected module v4.43 Device: Fly-SLT100 Checking data, wait... Action: write flash NAND write: Firmware Fly-SLT100_Hummer-HT1_SLT100_HMERID_PCB04_GPRS_MT6228_S02.MAUI_06A_W 06_36_MP_V36_M3.00R_2007-07-26_En_Ru_Ua.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: SLT100_HMERID_BOOTLOADER_V005_MT6228_MAUI_06A_W06_ 36_MP_V36.bin nfi area detection (2 cores) finished: Ok interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6228:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: MAUI.06A.W06.36.MP.V25 detect NAND info... number of areas/bytes to read: 1:00010000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: SLT100_MLAB_BOOTLOADER_V005_MT6228_MAUI_06A_W06_36 _MP_V25.bin warning: id-page1 area is invalid nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: SLT100_MLAB_PCB04_GPRS_MT6228_S02.MAUI_06A_W06_36_ MP_V25.BIN project-id: MAUI.06A.W06.36.MP.V25, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [standard] type (04) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: SLT100_HMERID_BOOTLOADER_V005_MT6228_MAUI_06A_W06_ 36_MP_V36.bin nfi area detection (2 cores) finished: Ok startup code area #1 check... done number of cores: 2 loading files... number of areas: 2 done write... write bootloader... . write core... error: can not write flash (4): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 1 min 17 sec Remove/Install battery now ! | |
06-12-2013, 12:01 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, I think that in this situation it may be problem with hardware. Try to open phone first and check it's hardware, clean water, heat flash chip. |
fly B700 flash error!!!!!!!!!!!! | msantar | Infinity-Box | 9 | 10-08-2009 10:43 |
fly sl500i flash error | AY29!4LYF | Infinity-Box | 6 | 04-20-2009 17:45 |
FLY SLT100 + Black screen after flash | rodriges | Infinity-Box | 5 | 03-13-2009 00:57 |
Fly Slt100 | Werra | Various | 1 | 11-04-2007 12:24 |
Wanted Fly-SLT100 for tests | InfinityHelp | Infinity-Box | 0 | 11-02-2007 13:56 |
