05-24-2008, 09:14 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Fly Sx200 Cannot Be unlocked Tried all available unlock option but same.... When power on phone ask for NP CODE ---------------------------------------------------------------------- COM4 [VCP0] selected Device: Fly-SX200 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:5F03:0005 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: MASS2_FLYUKVG_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_3 6_MP_V23.BIN ver. sw2: MAUI.07A.W07.36.MP.V23, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 89881500010001:89881500000000 Backup required data Done Patch required data... ........................................... lock area found Patch required data Done Special operation... Special operation Done Write... flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 Write: lock-area-1 Write Done Finalization... Finalization Done Finished, time used: 45 sec Remove/Install battery now ! -------------------------------------------------------------- any solution how to unlock it...support? Also when i do read codes it shows lck status like this --------------------------------------------------------- COM4 [VCP0] selected Action: read codes unlock method: read codes Model: Fly-SX200 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:5F03:0005 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: MAUI.07A.W07.36.MP.V23 Version: EZIO25_07A_HW 44 byte(s) read imei: 3504*********xx connection Ok 157 byte(s) read Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 0000 Finished, time used: 14 sec Remove/Install battery now ! |
05-25-2008, 08:57 | #4 (permalink) | |
Here is some news: http:///vbb/showthread.php?t=542283 | |
Fly SL600 can't be unlocked | patric | Infinity-Box | 14 | 04-04-2010 03:25 |
Fly SX200 dead while Unlock | Nasmi | Infinity-Box | 1 | 01-23-2009 17:00 |
Fly SX200 will not unlock on M-Module 2.24 | drancill | Infinity-Box | 4 | 06-29-2008 12:52 |
How to unlock 100% NEW v24 that cannot be unlocked with free soft | Safrane | E-Gold Based Phones | 11 | 10-14-2003 00:19 |
