07-18-2008, 03:27 | #1 (permalink) |
Insane Poster Join Date: Jan 2007 Location: philipines
Member: 437258 Status: Offline Thanks Meter: 23 | LG-KG245 unlock done cable use RJ45 LG7050 pin out: keyboard top 1.........24 11: Phone Tx (RJ45 pin-3) 12: Phone Rx (RJ45 pin-2) 13: Gnd logs: COM30 [VCP0] selected Device: LG KG245 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 359103001...... current otp imei: 359103001...... file saved: C:\Program Files\InfinityBox\LGA\eeprom_359103001692887_LG KG245_20080717-174320.B1E.bin .......... version: 505-03V10a61KG245P64FL Check flash Done Check space... current eeprom imei: 359103001...... .................................................. .............. finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 55 sec Remove/Install battery now ! |
The Following User Says Thank You to yhob For This Useful Post: |
07-18-2008, 11:34 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @yhob Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
LG-KG245 unlocked with infinity | topnoyze | Infinity-Box | 2 | 02-10-2009 07:05 |
Lg Kg245 Unlock | inat | FuriousGold | 22 | 05-17-2007 22:16 |
LG kg245 Unlock???? | macs1222 | LG | 4 | 12-07-2006 10:16 |
Lg Kg245 Unlock Any Solution Yet ? | simclub1 | HWK | 1 | 10-08-2006 15:16 |
lg KG245 UNLOCK | alloujdi | LG | 1 | 06-25-2006 05:33 |
