01-12-2010, 17:22 | #1 (permalink) |
Freak Poster Join Date: Sep 2009 Location: www.telefony-nawigacje.pl
Member: 1122479 Status: Offline Thanks Meter: 22 | Fly-ying f003 nor supported? module v3.05 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6235:8A04:8A01 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND NAND flash chip: S_DA_NAND_UNSUPPORTED_DEV_ID internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_DA_HANDSET_ROM_INFO_NOT_FOUND bootcode current/expected: 3.2, 3.2 done Set baudrate (115200)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 26 sec Remove/Install battery now ! THIS CPU NOT SUPPORTED? |
The Following User Says Thank You to seba6250 For This Useful Post: |
01-13-2010, 16:09 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to read flash from phone with this software: http://www.infinity-box.com/download...e_v3.07_v1.rar I don't think that it will be success for sure, but I hope that this software can detect flash chip details better. Let's see results. |
01-13-2010, 17:13 | #8 (permalink) |
Member: 1122479 Status: Offline Thanks Meter: 22 | same situation COM32 [VCP0] selected module v3.07 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! CPU: 6235:8A04:8A01 bbchip secure ver: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND strange NOR detection result: 0BC3 NAND flash chip: S_DA_NAND_UNSUPPORTED_DEV_ID flash id[FFFF]: 0098:00D100900015 NAND_UNKNOWN internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND boot style: S_DA_HANDSET_ROM_INFO_NOT_FOUND bootcode current/expected: 3.2, 3.2 done Set baudrate (115200)... done error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 48 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to seba6250 For This Useful Post: |
02-09-2010, 17:18 | #12 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Try to use this new software to solve this problem: Code: NAND flash chip: S_DA_NAND_UNSUPPORTED_DEV_ID flash id[FFFF]: 0098:00D100900015 NAND_UNKNOWN Waiting for your results. |
02-11-2010, 13:28 | #13 (permalink) |
Member: 1122479 Status: Offline Thanks Meter: 22 | COM6 [VCP0] selected module v3.09 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.936.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND warning: NOR flash chip is not installed NAND flash chip: S_DONE flash id[0014]: 0098:00D100900015 [TOSHIBA] TC58NVG0S3AFT flash size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00010000 external RAM: S_DA_DEVICE_NOT_FOUND done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: L003A_MIC3_TY1G_WIFI1_TV1_ML_SM1_TH1_V4.01 detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: L003A_BOOTLOADER_V005_MT6235B_L003A_TY8A_WIFI_TV_E N_TR_SM_V3_00. nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: L003A_MIC3_PCB01_GPRS_MT6235B_S01.L003A_MIC3_TY1G_ WIFI1_TV1_ML_SM1_TH1_V4_01.BIN project-id: L003A_MIC3_TY1G_WIFI1_TV1_ML_SM1_TH1_V4.01, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.09, database date: 08.02.2010): L003A_MIC3_PCB01_GPRS_MT6235B_S01.L003A_MIC3_TY1G_ WIFI1_TV1_ML_SM1_TH1_V4_01.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Program Files\InfinityBox\ChineseMiracle\fly-ing f003 bodzio\L003A_MIC3_PCB01_GPRS_MT6235B_S01.L003A_MIC 3_TY1G_WIFI1_TV1_ML_SM1_TH1_V4_01__firmware_201002 11-132702.B4M.bin Disconnect... done Finished, time used: 13 min 23 sec Remove/Install battery now ! |
02-11-2010, 13:31 | #14 (permalink) |
Member: 1122479 Status: Offline Thanks Meter: 22 | but tell me mr.mobi is mt6235b is supported by language editor?? Editor version: [1.28.20.6] private Detected crypted Chinese Miracle file... Crypted fullflash loaded Loading fullflash file... OK -------------------------------------------------------------------------------------------------------------- MTK Rom Info Version: 07 ROM version: L003A_MIC3_PCB01_GPRS_MT6235B_S01.L003A_MIC3_TY1G_ WIFI1_TV1_ML_SM1_TH1_V4_01.BIN MCU version: L003A_MIC3_TY1G_WIFI1_TV1_ML_SM1_TH1_V4.01 Build time: 2009/10/10 09:30 Hardware: L003A_08B_HW -------------------------------------------------------------------------------------------------------------- Detected NAND firmware... -------- NAND Flash info -------- Page size in bytes: 0x0800 Block size in pages: 0x0040 Flash size in blocks: 0x0400 ------------------------------------ Detected spare bytes, clear fullflash from it... Error! Please, contact support! |
02-11-2010, 15:07 | #15 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hi, Updated Language Editor software with 6235 support should be released in nearest future. pls, send to us backup file: [email protected] or upload files to http://rapidshare.com or http://4shared.com |
Request|Flasher To Fly-Ying F003 Iphone Style (Firmeware need) | naty48 | Chinese Models & Cloned Phones | 4 | 02-27-2010 17:43 |
Fly-Ying F003 MTK6235 E04 Need Help | naty48 | Chinese Models & Cloned Phones | 0 | 02-26-2010 14:53 |
fly ying f003 | ****Nihat**** | Infinity-Box | 1 | 01-25-2010 20:07 |
infinity cant detected Fly-Ying-F003 | delchoni | Infinity-Box | 10 | 11-16-2009 22:14 |
Fly Ying f003 & Verizon??? | VideoE | Chinese Models & Cloned Phones | 0 | 11-09-2009 20:41 |
