Old 01-15-2021, 08:11   #16 (permalink)
Member: 477842
Thanks Meter: 58
Originally Posted by Franky_36 View Post
Hi, in the mtk module you need custom da file, auth.file, preloader.bin and depending on the security of the mobile.
With the qualcomm idem theme, you need a custom loader and it will surely give you an error, because you need authorization to the server.
It would also be very helpful if you indicate which phones they are, the more information the users provide, the better for others, if you do not comply with the basic rules of the forum and the section in question they will not answer.
Is it possible to unlock this phones Online via Infinity Server,
I could remove the pattern lock, reset screen lock code and possibly FRP ?
Old 01-15-2021, 15:49   #17 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 1,831
Hi, from the models mentioned in your previous post, it all depends on the security patch, how updated it is, a safer way until they are supported or they get updates, the infinity team is to do it by isp pinout or jtag, you can also try to do it by meta mode the mtk model. The models with qualcomm processor do or do have to be done by isp pinout or jtag as it requires authorization to the server.
Old 01-16-2021, 23:20   #18 (permalink)
Member: 477842
Thanks Meter: 58
It`s most problematic because for a normal reset of the user's screen lock code, you will have to scratch the memory to ISP TP or desolder memory it from the PCB and this unfortunately will void the producent manufacturer's warranty.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.11334 seconds with 8 queries
